| Re: Brightness of DAB clock radio displays
I had the same problem as you, and actually got one of the Revo Bliks mentioned in the previous post - although not the one with Internet Radio - however, it was almost impossible to read the display from any distance whatsoever, plus the firmware was full of bugs, so many in fact that I'm not even going to try to list them. I must stress however that that may not be the case with the Internet Radio version.
However, I recently purchased a Pure Chronos II and must say that I am delighted with it. It has a sensor which makes the display brighten and dim according to ambient light, is easy to read, and has some good features on the alarm side of things, e.g. 4 different ones can be set, each alarm can be set to come to a different station and at a different volume setting, very handy for example when you want to listen to a music program at night with volume turned down, but for the alarm to come on quite loud in the morning on say a news channel.
Finally, I have come across no problems with it so far, albeit only a week into my ownership,
Cheers,
Martin.
