Can I convert FM input to use to boost AM?
Old 23-08-2009, 5:39 PM   #1
3,539, Level: 13
Points: 3,539, Level: 13 Points: 3,539, Level: 13 Points: 3,539, Level: 13
Thanks: Gave 7, Got 3
Hello
I already have a 8 way aerial amplifier, which has an input for FM, however, I need to boost my AM signal. Problem is the connection for FM and AM differs on my tuner. FM requires the standard coax plug where as the AM requires, well, a fork like connection. Does a convertor exist that would allow me to convert the FM signal to AM?
Or will I simply have to purchase a boosted AM aerial, and if so, which would you recommend please?
Old 23-08-2009, 10:23 PM   #2
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
Re: Can I convert FM input to use to boost AM?
A converter would not be appropriate.
AM broadcast is in various bands at frequencies of about 180 KHz-26MHz. The normal medium wave AM band is about 500 KHz to 1.6 MHz.
FM broadcast is 88-108 MHz - much higher frequency.
For AM, I would suggest a simple length of wire - also known as a "longwire" aerial.
This is the simplest aerial that anyone could DIY.
Try Googling " 'medium wave' longwire aerial"
Chris Muriel, Manchester
Old 24-08-2009, 4:53 PM   #3
3,539, Level: 13
Thanks. No DIY skills so purchased this from maplins...
AM/FM Radio Amplified Aerial : Radio Aerials : Maplin
Works really well with FM, however, there is a problem with the AM. The amplified aerial has two prongs for AM, which I connect to my tuner but there is still no signal. I then found in the tuners instructions that it still requires the loop in order to receive AM signal. I no longer have the loop that came with the tuner and not sure where to go from here as the loop it refers to has a two pin connection jack. Any advise?
http://www.box.net/shared/xmc07mjcc4
Old 25-08-2009, 9:25 AM   #4
15,699, Level: 30
Activity: 11.1%
Just use some cheap wire of similar gauge and length to what was on the original loop aerial to approximate the original and connect that. The length and dimensions are not critical.
Old 25-08-2009, 9:46 AM   #5
11,437, Level: 25
Points: 11,437, Level: 25 Points: 11,437, Level: 25 Points: 11,437, Level: 25
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 257, Got 219
manuals - Folder Shared from Box.net - Free Online File Storage
I have one of these Maplin aerials and it works very well sitting on a window sill. OK for FM, passable for AM.
I had an AM/FM tuner that had a conventional ferrite rod aerial affixed to the back on a hinge which you turned for best AM reception. As I recall this was 'hard wired' into the unit.
Powered by
 Latest popular product prices
Roberts R9993
5 prices from
 £17.30 Click to show/hide the offers
Roberts Gemini R9954
3 prices from
 £27.14 Click to show/hide the offers
Pure One Mi
8 prices from
 £29.47 Click to show/hide the offers
Pure ONE Mini
4 prices from
 £39.99 Click to show/hide the offers
Roberts Classic DAB
9 prices from
 £34.84 Click to show/hide the offers
Roberts DreamTime
4 prices from
 £40.78 Click to show/hide the offers
Pure ONE Elite
4 prices from
 £66.26 Click to show/hide the offers
Roberts sportsDAB 2
6 prices from
 £62.99 Click to show/hide the offers
 Updated February 13th at 12:30pm. Prices include delivery.
