Re: Anyone ever installed/hung a 42" plasma on a timber-framed wall?
hmm.. i thought i'd replied to this - obviously not (damned PC)
is it a cob wall? (i would assume so if timber framed and period)
cob can be a solid material if its not cream crackered, you'll need to open the wall up to see exactly what it looks like, if you're confident in doing this bit, putting the plasma up wont be a problem at all.
as per the other advice, you'll ideally need to stick some timber strucure/framework into the wall itself. if my assumptions are correct and its cob, i honestly think your best bet for holding things in place would be resin fixing rather than some form of expansion bolt.
regards,
jt
