AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Custom Installers and Installations
LinkBack Thread Tools Display Modes
Old 18-12-2006, 6:09 PM   #1 (permalink)
madman1178's Avatar
Thanks: Gave 8, Got 10
aluminium frame stud plasterboard wall plasma mounting help
i need to mount a 30k plasma on a plasterboard wall, i have been told by the builders that the wall is an internal aluminium stud framed wall with plasterboard (18mm he thinks) the studs are 18" apart and are in the right position to be central to the plasma.
Advice please regarding what to use and how to use it to mount it
thanks!
madman1178 is offline
Old 18-12-2006, 8:45 PM   #2 (permalink)
jonny round boy's Avatar
Thanks: Gave 0, Got 13
Re: aluminium frame stud plasterboard wall plasma mounting help
30K?!?!?!
I hope that's not £'s - if it is, it should be a pretty big screen...
As for the studs in the wall, I've seen the galvanised steel studding, but not heard of it in aluminium. Even the steel stuff I would be wary of fixing to - the steel is pretty thin & it's easy to strip out the screws. It's designed to support the weight of the plasterboard, but I don't know about anything else. Best thing I can suggest would be to find out who makes the studwork, and check the manufacturer's website for the specifications.
I've never known plasterboard to be 18mm thick either, unless it's a double layer of 9.5mm. Plasterboard is usually either 9.5mm or 12.5mm thick.
Hope someone else can help further.
My Equipment List: Samsung LE32R73BDX 32" LCD; Shuttle SN41G2 HTPC;
Sherwood RV-4080R Dolby Pro-Logic Amp; Tannoy 632 Speakers;
Toshiba SD330E DVD Player; Silver Slimline PS2
jonny round boy is offline
Old 18-12-2006, 8:50 PM   #3 (permalink)
OK, just re-read it - I'm guessing you mean 30kg, not £30k!!!
Old 18-12-2006, 9:11 PM   #4 (permalink)
Thanks: Gave 40, Got 32
I'd be tempted to put a slim FALSE wall in front of the existing wall, it will have all sorts of benefits, cable tidying being one, and you may even want to use this for your equipment.... integrating floating shelves and so on....
Fujitsu P50XHA40US , Arcam FMJ DV139, AV8, Bryston 4B SST,9BST, PMC OB1 Fronts, CB6,DB1+ Rears, SVS SB12 Sub, Chord Cables.
http://www.invelos.com/dvdcollection.aspx/djblade
DJBlade is offline
Old 20-12-2006, 12:44 AM   #5 (permalink)
madman1178's Avatar
yeah, 30kg not £30k....i wish!!...
I did consider a false wall, but all the cables and other equipment will be in the adjoining room.
if is fixed a wooden panal to the metal frame with nuts and bolts and mounted the plasma to that what do you think?
aluminium, frame, mounting, plasma, plasterboard, stud, wall
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
