AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Custom Installers and Installations
LinkBack Thread Tools Display Modes
Old 15-09-2006, 3:02 PM   #1 (permalink)
Wall Mounting an LCD Help Please
Hi i'm wondering if someone can help me? i'm think about buying a 32" LCD and want to wall mount it in my bedroom,the problem i have is i only have 60mm of plasterboard before i come through to the landing if i were to drill a hole.i know fixings are not that long but would 60mm of plasterboard be able to hold the weight of the TV. any help is much appriciated.thanks
crag949 is offline
Old 15-09-2006, 4:14 PM   #2 (permalink)
Thanks: Gave 0, Got 12
Re: Wall Mounting an LCD Help Please
If you look at the next thread down...you will see a Plasterboard thread.
LCD is much lighter than a Plasma....it is recommended that you use a number of fixings.
They are teh type that expand behind the plaster board.
I think quoted figures were, pull out force around 60k load strength 10k, per unit, so if you use 8 or so..all is good.
http://www.screwfix.com/app/sfd/cat/...25484&id=11143
Yes, I know its "the" not "teh"...tell my fingers that!
Skeet is offline
lcd, mounting, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wall mounting a LCD lockers LCD Brackets and Mounts 3 17-05-2006 6:38 PM
LCD/plasma for wall mounting david230 LCD Brackets and Mounts 1 24-04-2006 11:52 PM
LCD wall mounting on plasterboards ARD Home Cinema DIY 6 20-01-2006 10:23 AM
Wall mounting a LCD over a radiator?? Pardsme LCD Brackets and Mounts 12 13-12-2005 2:43 PM
Wall Mounting the Tevion LCD Deano70 LCD Brackets and Mounts 5 26-09-2005 10:12 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
