AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Cinema Construction and Configuration > Custom Installations and Installers
Notices
Wifi control for Primare DVDi10 GV0301 Networking 0 21-11-2008 10:09 AM
using a PDA for IR or WiFi remote control candg Remote Controls 1 11-08-2008 10:04 PM
Code for Arcam CR 80 to control Primare DVD 26? pepelu Arcam Owners' Forum 2 31-12-2005 1:47 PM
IR control over Wifi andyatkins Remote Controls 2 27-02-2004 6:38 AM
Old 24-11-2008, 7:45 AM   #1 (permalink)
Hopefully this is the right spot for my question.
The DVDi10 has a RS232 port. The idea is to control this device wireless via the RS232 port with known RC5 codes from Primare.
There is a possibility connecting the mentioned port to NAS via USB. Could this work? What software (and perhaps additional things) do I need to control this DVDi10 via iTouch and a Wifi connected notebook?
Thanks,
Vincent
VincentG is offline   Reply With Quote
Old 24-11-2008, 1:20 PM   #2 (permalink)
vex
Assured Advertiser
Location: East Anglia or Home Counties, depending on the day!
Thanks: Gave 7, Got 165
Re: Wifi control for Primare DVDi10
RC5 codes are IR instructions, not RS232 strings so you would have to source those first.
Then you have a problem of control. RS232 ports do not give you direct access to web type pages, you would be best to interface it to something like a Pronto or RTI type remote that gives you RF portability with buttons on the remote that trigger the base station to spit out the relevant RS232 strings.
I am not sure if either of these base stations allow you to access it off the web to be able to simulate button presses from within the base station.
HTH
V.
Be careful out there forumites - 89% of statistics are made up.
Life's better when it's wired! - WiredLife
Proud to be an AVForums sponsor and assured advertiser
vex is offline   Reply With Quote
Old 24-11-2008, 2:41 PM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 91, Got 1,259
Thanks,
Vincent
HI Vincent i dont think you would be able to connect the RS232 serial control port to a NAS drive to do anyhting useful. For ipod/iphone/itouch and laptop control you would need an RS232 to TCP/IP bridge with buil in webserver and control system GUI.
Something like Aurora Multimedia - IP Control Systems, Multi-Image Video Processors, DVI and HDMI Distribution... WACI junior would be able to do this you would need to create a GUI and then program the RS232 strings into the software.
It would be an ambitous project for a Pro so unless you have a a background in software or control engineering you may want to subcontract this out. You can of course buy the kit and have a play...
Just to satisfy my curiostiy why control a DVD player with a laptop/phone? I personally cant see the benefit unless you already control the rest of your system like this.
Thanks to everyone who visited our stand at the NEC
Life's better when it's Wired! - WiredLife...
hornydragon is offline   Reply With Quote
Old 25-11-2008, 7:56 AM   #4 (permalink)
Assured Advertiser
Thanks: Gave 96, Got 828
Hello all
The Aurora WACI kit would do the job and an iPhone or iPod touch can be used as the user interface.
Aurora provide Free GUI creation software (Aurora Multimedia - IP Control Systems, Multi-Image Video Processors, DVI and HDMI Distribution...) - with a bit of perseverance (and supplier backup) even the non Pro can get a simple set-up going without too many sleepless nights.
Joe
Joe Fernand is offline   Reply With Quote
control, dvdi10, primare, wifi
