Hi Guys
Long time lurker, 1st time poster here, hope you can help.
I'm currently in the process of chasing some HDMI cables into our lounge internal wall, and we're having some problems sourcing the faceplates we need.
We've already chased out the wall, the projector will be ceiling mounted at the back of the room and we are planning on having 3 hdmi sockets just behind it on the wall, with the cables run down to our av area under the stairs. The main problem we're having is with right angled HDMI faceplates.
Because the wall is solid and not that deep - we can't use 47mm back boxes, so are planning on using hdmi plates with right angled connectors.
I've had no joy in finding a double hdmi single size face plate (in brushed steel), so we're now thinking of making our own.
Current plan is to buy blank face plates and cut holes then attach these
Right Angle HDMI Coupler Adapter with glue to the back side of the face plate. Do you guys know of any similar adaptors out there that have screw fit plates on them?
A bit like this
Failing that if you know of anywhere that has a ready made plate on offer, or have any better ideas I'd appreciate it!
On another note we're after a single rca connection plate as well, so far I can only find doubles.
Thanks in advance!
Claire
