Pretty sure I can find the relevant symbol, but any more detail on implementation / how you would do it would be awesome. All my control at the PC end would be achieved using auto-it, with the exception of the wake on lan implementation. Currently the PCs come on automatically at 7.30 am and switch off automatically after 10pm (as long as there isn't a logged in user) - but people still switch them off, plus a couple of them have failed to come on in the past for whatever reason (duff bios I guess?)
I'm guessing that I don't need to bother going into scripting to send a simple message to an IP address / port in Simpl, but that the wake on lan part will require a little bit of code. It seems like we manage the PCs and the control systems independently at the moment, and that there's massive potential to combine the two, especially as it's the same people managing AV and IT - we also have some devices that aren't connected by serial, but that have PC based control software and USB ports, so it saves on extra Crestron hardware.
Originally Posted by 360Degree You either use a TCP/IP Client or Server (depending on how you want it to work) symbol OR if you're into your Simpl+ (this is how I would do it) you write a module that can open a direct socket connection to a specified IP address and port.
Check out the Simpl+ help file for more info on direct socket connections.
If you need more info post back I will post some screenshots of the relevant bits. |
