new here, need help!
Old 15-11-2009, 6:27 AM   #1
1,317, Level: 8
Points: 1,317, Level: 8 Points: 1,317, Level: 8 Points: 1,317, Level: 8
Hi, i just got a 55inch lcd and plan on wall mounting it.but i want to have all the home theater equipment (dvd player, cd player, etc) in the room behind where im mounting the tv.all the cables will pass through the wall behind the tv and into the next room.
Is this possible? will i b able to use remotes for the dvd player? if so how?
please im so lost! help me!
Old 15-11-2009, 6:35 AM   #2
2,920, Level: 12
Points: 2,920, Level: 12 Points: 2,920, Level: 12 Points: 2,920, Level: 12
Thanks: Gave 87, Got 120
Re: new here, need help!
Something like these would do the trick
NexGen Solutions - X-Ray Remote Extende - Make your infrared remote work using radio signals
or an IR repeater of some kind. I've not used this sort of set up so can't comment on how effective they are but hopefully that gives you a bit of a starting point!
Old 15-11-2009, 6:42 AM   #3
1,317, Level: 8
thanks!
that gives me a great start!
anyone else have any ideas/input?
Old 15-11-2009, 10:14 AM   #4
8,116, Level: 21
Points: 8,116, Level: 21 Points: 8,116, Level: 21 Points: 8,116, Level: 21
Thanks: Gave 25, Got 91
Keene Electronics
Old 16-11-2009, 11:15 AM   #5
Assured Advertiser
Liam @ Prog AV's Avatar
27,664, Level: 40
Points: 27,664, Level: 40 Points: 27,664, Level: 40 Points: 27,664, Level: 40
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 6, Got 803
I would buy a remote with a wireless solution e.g. Logitech Harmony 895 or 1000, or Philips Pronto TSU-9200 with RFX-9200 extender.
How much does a cockney pay for shampoo? Pantene
call me: 01892 860801 / e-mail me: liam@progressive-av.com / twitter me: @ProgressiveAV
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Old 17-11-2009, 4:54 PM   #6
942, Level: 6
Points: 942, Level: 6 Points: 942, Level: 6 Points: 942, Level: 6
Thanks: Gave 4, Got 4
For a cheap and cheerful solution get an
SLX Omnilink Remote Control Extender from B&Q, you get a wire with 3 IR bugs on to stick on your kit, works off your Sky RF2 voltage or a seperate 12v PSU (Supplied). Does the same job as the Elan ones for half the price, and ultra reliable.
SLX Omnilink Remote Control Extender, 27872HS/04
