Would the following work?
I currently have Sky HD in the lounge and want to put this in 3 other rooms ideally so it can be viewed in HD (1080i) in all rooms.
I also have a blu-ray and media server which I would also like to be able to view in these 3 other rooms as well.
Therefore I was looking at this Infinius Matrix 4x4 switch.
HDMI over Cat 5 Matrix Switch 4x4
If I run cat 6 cabling around the house, I believe I can see the same and different sources in each room. E.g. watch sky in the lounge whilst watching a bluray in the bedroom etc. Is this correct?
Equally reading the description means I can change the source viewed in another room from within the room from the supplied remote?
Also if I bought a generic remote for each room e.g. harmony etc then I could play, pause, control the sky, blu ray, media server etc from within the other rooms?
I was also recommended the Pro 2 2 splitter so that I could use the 4 Matrix with an AV receiver in the lounge. Any thoughts?
Anything else I need to think of?
