help integrating future automation with pronto rfx9600
Old 09-11-2009, 11:19 AM   #1
2,595, Level: 11
Points: 2,595, Level: 11 Points: 2,595, Level: 11 Points: 2,595, Level: 11
Thanks: Gave 1, Got 10
hey guys
any chance any one may have integrated this older control box from future automation with the rfx9600by any chance?
Old 14-11-2009, 2:37 AM   #2
3,279, Level: 13
Points: 3,279, Level: 13 Points: 3,279, Level: 13 Points: 3,279, Level: 13
Thanks: Gave 14, Got 36
Re: help integrating future automation with pronto rfx9600
Usually the Future Automation box has RS232, IR and dry contacts so it is up to you on how you want to control it using the RFX9600. We usually do lifts, projector screens, e.t.c using relays. We prefer do do it with two relays so that we have "discreet" up and down. The push button method - 1 relay - also works but you have better control especially if you try to do some complex logic and macros with 2 relays.
I can not tell from that picture what interfaces that box has. Just ask them directly but probably it will have all the ones I mentioned above.
