Speakercraft In-wall Speaker Combinations
Old 04-11-2009, 12:16 PM   #1
miceri's Avatar
4,314, Level: 15
Points: 4,314, Level: 15 Points: 4,314, Level: 15 Points: 4,314, Level: 15
Thanks: Gave 47, Got 65
Question Speakercraft In-wall Speaker Combinations
Hi Folks,
I need some help with Speakercraft built in wall speakers.
I am looking at installing LCR + Rears in the walls, but am unsure which combination of speakers to buy. I know that I should really match the series within the Speakercraft line up, i.e. Series 1, Series 3 etc.
But which combination within the range, and does it matter?
The room is 2,6m wide, 3.6m long.
Windows effectly line the LHS wall - So no space for a left wall spaced speaker. So I shall be mounting on the rear wall.
Currently the ceiling is not an option...
Can I mix and match in these combinations, and if so what is best for a small room, rears mounted on back wall (Single or dipole?)
3 LCR SpeakerCraft AIM7 MT Three
2 Rr SpeakerCraft AIM5 Three
5 All SpeakerCraft AIM7 MT Three
1 C Speakercraft AIM LCR One
2 Rr Speakercraft AIM Cinema Dipole One
2 LR Speakercraft AIM Cinema One
2 Rr SpeakerCraft AIM7 MT One
3 LCR Speakercraft AIM LCR One
3 LRC Speakercraft AIM LCR One
A sub will be added later...
Any suggestions, experience of in-wall builds, speaker matching etc will be very gratefully received.
I am looking to order within a week or so.
Thanks //miceri
Old 22-11-2009, 11:10 AM   #2
S2Tigger's Avatar
1,352, Level: 8
Points: 1,352, Level: 8 Points: 1,352, Level: 8 Points: 1,352, Level: 8
Thanks: Gave 185, Got 44
Did you ever get a response?, I'm just about to install a set up and am interested in the speakercraft in wall speakers..
What did you end up installing?
Darren
