Good quality 50 x 50 PNG logos
Old 31-10-2009, 10:55 PM   #1
1,976, Level: 10
Points: 1,976, Level: 10 Points: 1,976, Level: 10 Points: 1,976, Level: 10
Thanks: Gave 0, Got 5
Hi all, does any one know of a good site where i can obtain good png format logos 50 x 50 pixels in size? i require all the radio stations and sky programme logos,
many thanks
Carl.
Old 31-10-2009, 11:04 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Good quality 50 x 50 PNG logos
For pronto?
Old 31-10-2009, 11:07 PM   #3
1,976, Level: 10
For the WCU600 by Opus.
Old 31-10-2009, 11:09 PM   #4
Assured Advertiser
63,997, Level: 61
ah same format as pronto. Tis the holy grail and i dont know of a single resource lots of faffing and cropping really and some dont have a logo that can be made square or easily edited invest in photoshop or find an unemployed graphic designer
Old 31-10-2009, 11:12 PM   #5
1,976, Level: 10
Tried to edit a logo taken from the Lynsat site, cropped it and saved it as a Png image using MS paint of all things, but my screen composer still didnt see it as a valid png image, hence, here i am needing a hand..
carl.
Old 31-10-2009, 11:28 PM   #6
Assured Advertiser
63,997, Level: 61
Photo shop or other proper image editor make sur eyou have plenty of CPU power and buy a version the free ones often cant do the format editing and transparency you need
Old 01-11-2009, 12:06 AM   #7
Michael's Avatar
5,617, Level: 17
Points: 5,617, Level: 17 Points: 5,617, Level: 17 Points: 5,617, Level: 17
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 380, Got 165
You don't need to pay copyrights, do you?
If you don't, as long as theer are not too many, I could spend 1/2 an hour firing logos through TheGimp, if you like.
Just tell me what you need.
Old 01-11-2009, 12:37 AM   #8
2,595, Level: 11
Points: 2,595, Level: 11 Points: 2,595, Level: 11 Points: 2,595, Level: 11
Thanks: Gave 1, Got 10
got all the channels and radio logos with 2state but for my prontoedit lib only.. not sure if they can be converted
cheers
Old 01-11-2009, 12:39 AM   #9
Michael's Avatar
5,617, Level: 17
Activity: 1.7%
How many are there?
Send me one to see if I can do them efficiently, then you can just send me a zip with the rest.
Old 02-11-2009, 8:47 AM   #10
3,191, Level: 13
Points: 3,191, Level: 13 Points: 3,191, Level: 13 Points: 3,191, Level: 13
Try LYNGSAT*LOGO*-* United Kingdom for logos.
Also, use 'Batch Convert' - a feature that is in many image editing software releases such as Adobe Fireworks or Photoshop. You may even be able to find a free image resizer online...
