Cat6 for Multi-room AV and Stop-gap solution
Old 30-10-2009, 5:09 PM   #1
2,782, Level: 12
Points: 2,782, Level: 12 Points: 2,782, Level: 12 Points: 2,782, Level: 12
I am re-wiring the whole house (8 zones) and would like to take the opportunity to put in multi-room AV. I require Ethernet, audio, video and lighting control at each of the 8 zones with touch panel wall plate controls.
At this stage, I don't have the budget to install a fully integrated system (e.g. Control4 or OPUS, 35-40k quoted by dealer). So I want to put in cables first from a hub to each zone and stay as open standard as possible to allow retro-fit later on.
In the mean time, I would install some stop-gap tactical solutions until a budget is there for the full system.
Advise on the following would be greatly appreciated:-
Q1: Is 4xCat6 to each zone enough, say for a Control4 retro-fit in the future (or any system)?
Q2: Do I need a coax to each zone as well? Why?
Q3: I am thinking of terminating these 4xcat6 in the ceiling void with an access panel. Ethernet (data)/HDMI (TV) wall plate and ceiling speakers will be run from this terminating point to a desire location around the zone.
Q4: For a touch screen wall plate, should I run another cat6 (injected with POE) from this terminating point to the light switch location by the doorway?
Q5: As a stop-gap solution, I am going to use SONOS for audio, a HDMI matrix over cat6 for video distribution and RAKO for lighting. Does this make sense?
Q6: I am struggling to decide how to control all 3 systems with just one remote control. There are iPhone apps which can control SONOS and RAKO but not the HDMI matrix. Alternatively, Pronto/Nevo can be programmed to control the matrix and RAKO but not the SONOS. Any suggestion?
Q7: Is there any stand-alone IP based touch screen wall plate that can be programmed to control these 3 systems?
Q8: Does anyone provide just programming service for Pronto or Nevo (not part of an install)?
Sorry about the long post and many thanks for your advice in advance.
Mo
Old 30-10-2009, 8:17 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Cat6 for Multi-room AV and Stop-gap solution
Q1: most system need more than just Cat5/6
Q2: its reconmended
Q3: see answer to Q1...
Q4: see answer to Q1...Most need more than just Cat5/6
Q5: Why spend 40-70% of the required budget on a stop gap?
Q6: See the answer to Q5
Q7: Probably its called a PC...
Q8: Yes. (Well prointo in our case)
Also if rewiring why Rako?
Old 31-10-2009, 10:13 PM   #3
101music's Avatar
2,799, Level: 12
Points: 2,799, Level: 12 Points: 2,799, Level: 12 Points: 2,799, Level: 12
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 5, Got 9
I would advise looking around for more competitive quotes, or asking those involved to provide a system that can get you going in a few rooms for now.
HD is right, why spend what is still a considearble amount of money on a stop-gap.
If it was me, i'd put in the basic processors and remote controls for what you want, up to your budget, with a view to adding to the system when you have the finances in the future.
Old 31-10-2009, 11:01 PM   #4
Assured Advertiser
63,997, Level: 61
That does seem high considering I am putting in a full system to a 4 bed large house using Naimnet and Digilinx with HD video and Lighting control for not a whole lot more.
Fitting that system to 4 rooms and wiring the others should cost a lot less than going for a stop gap solution and then fitting another in a year or so especially considering the wiring complexities
