Originally Posted by padarom The AV distribution system is a Niles ZR6 audio and VS6 video system. Actually the arial feed is coming through a BT Vision box then to the AV multiroom distribution system. |
So is this a composite or component signal? I just had a quick look at the specs of the BT Vision Box and it seems it does not output composite or component. It seems it outputs only s-video and scart. How are you using this with a component video matrix switcher?
This is how I would troubleshoot IF you use a composite or component signal signal into the Niles switcher:
1) Take the signal out of the BT box and connect it direct to a tv. If the quality is ok then the problem is the Niles matrix switcher or the cables from the switcher to the tvs.
2) Do you have other video sources in the switcher? How is their quality?
3) What cables are you using for video? Normal RF cable is not suitable. You should use either bulk RG59 or RG6 "serial digital" cable and terminate it or use premade component or composite cables.
4) If you are only using composite then if you the use the green RCA in and out on the matrix switcher might still work to send composite to the tvs.
But how I would do it if the BT box only outputs scart is I would convert it to component using a suitable interface and then go into the matrix switcher.
I have no experience with the BT box so a pro from the UK has to confirm what if what I am saying above is correct.
