Hope this is the right place to post this. Have just moved to a new flat with a pre-installed Loftbox. We're not using Sky. In the lounge, I've split the aerial downlead, one split going to the lounge TV, and the other returning to the Loftbox for distribution to the rest of the flat.
My LG M2794DP TV doesn't work on DTV when connected any of the rooms that are fed by the Loftbox. I put it into analogue mode, and I can see the picture, but there's lots of interference. No wonder DTV doesn't work at all.
But - my 37" LG LCD works perfectly when plugged into the same sockets via the same coaxial cable. So, it's the TV you might say.
However, when I plug the 2794 into the main aerial socket in the lounge (the Loftbox downlink), it works. So, it can't be the TV you might say.
FWIW, the 2794 *was* working for a while, plugged into the radio socket of a "slave" socket, as I didn't have a gender changer, and I only had a male-male coaxial flylead. I think it's been "funny" since I moved it into the TV socket with a gender changer, but I'm not 100% sure.
Can somebody shed some light on this saga? I just don't get it.
