Ir control via pc or pda
Old 24-10-2009, 6:33 AM   #1
padarom's Avatar
962, Level: 7
Points: 962, Level: 7 Points: 962, Level: 7 Points: 962, Level: 7
Thanks: Gave 0, Got 2
Does anyone know of PC/pda hardware and software that can be used to control devices such as tv's or dvd players via infra red? It has to be capable of importing hex codes.
I need to use this to import and test device specific discrete ir codes before deciding on what universal remote control to offer clients.
Thanks.
Old 24-10-2009, 6:40 PM   #2
2,424, Level: 11
Points: 2,424, Level: 11 Points: 2,424, Level: 11 Points: 2,424, Level: 11
Thanks: Gave 11, Got 14
Re: Ir control via pc or pda
You might want to have a look at:
USB-UIRT Home
IRTrans Infrared Control System
I'm currently using the USB-UIRT with Homeseer ( Home Automation Systems - HomeSeer ) software as part of a home automation system.
I hope this gives you a starter for 10
Old 24-10-2009, 9:37 PM   #3
padarom's Avatar
962, Level: 7
Thumbs up Re: Ir control via pc or pda
Thanks for the response Jason. I too use Homeseer.
Old 26-10-2009, 7:51 AM   #4
Daz1970's Avatar
11,025, Level: 25
Points: 11,025, Level: 25 Points: 11,025, Level: 25 Points: 11,025, Level: 25
Thanks: Gave 0, Got 5
I use HP HX4700 running WinCESoft remote control II.
Works well learning codes and the loading of codes from a pcf.
Old 27-10-2009, 2:47 AM   #5
padarom's Avatar
962, Level: 7
Hi Daz1970,
Thanks for the tip.
Incidentally, I bought Remote Control II over the weekend and learnt some Sky codes into my HX4700. Worked a treat.
