Help with Installation, Callibration etc
Old 18-10-2009, 5:24 PM   #1
1,493, Level: 8
Points: 1,493, Level: 8 Points: 1,493, Level: 8 Points: 1,493, Level: 8
Thanks: Gave 4, Got 0
Hi, over the past year or so I have invested in various elements of a 5.1 separates system whenever I have been able to pick up what I felt was a bargain:
Onkyo SR607 Receiver
B&W P4 - Floorstanding Fronts
B&W DM601 S2 Book Shelf Rears
B&W CM-Centre Speaker
Rel Stampede Sub
I have done a basic set up of the equipment with some mid-quality wire from Richer Sounds and using the Audyssey mic supplied with the receiver. I am enjoying the results but ultimately I would like some professional help with achieving the best possible set up and with discretely placing wires and so on. I am particularly interested in bi-wiring (or not) and the alternative methods for hooking up the amp as well as the long term choice of cables.
Can anybody recomend a good (reasonably priced) supplier of these type of services. I am in North Manchester (UK).
Thanks,
Old 20-10-2009, 9:24 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Help with Installation, Callibration etc
For calibration check out http://www.imagingscience.com/isf_search.cfm I can reconmend Home Cinema Engineering, video and audio calibration, ISF and HAA
