Multi wall plate
Old 24-09-2009, 9:18 PM   #1
4,467, Level: 15
Points: 4,467, Level: 15 Points: 4,467, Level: 15 Points: 4,467, Level: 15
Thanks: Gave 16, Got 16
Multi wall plate
Hi all,
I'm trying to find somewhere where I can buy a wall plate that will terminate 1 x HDMI, 1 x component, 1 x ethernet & 1 x coax - this will be behind my tv terminating to my node zero in the basement.
The only place Ive found something is the site with 'europlates' but these seem to cost so much more than any number of separate plates.
Can anyone point me in the direction of somewhere I can either buy the bits to make my own, or buy pre made plates?
thanks
Will
Old 25-09-2009, 8:54 AM   #2
5,331, Level: 17
Points: 5,331, Level: 17 Points: 5,331, Level: 17 Points: 5,331, Level: 17
Activity: 5.4%
Activity: 5.4% Activity: 5.4% Activity: 5.4%
Thanks: Gave 33, Got 203
Re: Multi wall plate
For HDMI you would be better running the cable without wall plates - it can be tricky to create enough space in the back box to plug in the cable to the back of the plate. You could also use a pre-made component cable and coax of the relevant length to allow direct connection at each end. If your walls are dry-lined or stud walls then you can feed the extra cable length back into the wall until needed. to make it look neat you can then pull these cables through a brush plate (see ACA Apex for such plates).
that would only require the Cat5e to be terminated which would be quite straight forward. I would also suggest you run 2 x Cat5e (or even 4) as this would allow some flexibility in future for running audio/video over Cat5e should it be required as well as leaving additional cables for ethernet network connections.
Old 25-09-2009, 7:18 PM   #3
9,165, Level: 22
Points: 9,165, Level: 22 Points: 9,165, Level: 22 Points: 9,165, Level: 22
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 217, Got 360
May as well terminate the component though with either BNC or RCA for the amount of work involved - face plates with three of either should be ten a dozen.
Old 26-09-2009, 6:49 AM   #4
1,383, Level: 8
Points: 1,383, Level: 8 Points: 1,383, Level: 8 Points: 1,383, Level: 8
Thanks: Gave 2, Got 6
Why terminate any of them at all? As this is behind a TV and won't be seen, as neilball says, I would recommend just using neat brush plates to bring all the cables through the wall and then plug them into the back of the TV.
Any additional plug/socket combination is not good for any signals. And by bringing them through a brush plate, you may be able to get the TV nearer the wall because you won't have connectors sticking out from a wall plate.
I use these ones Aldous Systems (Europe) Ltd Single Gang Brush Faceplate
Graham
Old 26-09-2009, 10:53 AM   #5
vex vex is online now
10,371, Level: 24
Points: 10,371, Level: 24 Points: 10,371, Level: 24 Points: 10,371, Level: 24
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 27, Got 252
ACA now make a great little brush plate that sits behind your chosen faceplate range so that everything matches.
ACA-Apex Brush Face and Adapter Plate range
V.
SeanT (26-09-2009)
Old 26-09-2009, 11:43 AM   #6
9,165, Level: 22
Activity: 3.0%
Now that is a clever idea!
Old 27-09-2009, 10:02 PM   #7
4,467, Level: 15
Brilliant stuff, thanks for the replies!
I was first a bit worried about not terminating the cables, however good point on how much these will stick out.
Brush plate it is!
Old 28-09-2009, 7:19 PM   #8
2,634, Level: 11
Points: 2,634, Level: 11 Points: 2,634, Level: 11 Points: 2,634, Level: 11
Hi there
I am an installer and use a make called RPP I think it is. They are media plates avaliable from CEF wholesalers and are finished in gloss black. It all depends on the distance you are running cables as to whether you need to run pre-made cables or use CAT5 or CAT6 and terminate them. I do have pics avaliable to demonstrate how I have done mine.
Hope this is of some help
Old 28-09-2009, 8:22 PM   #9
1,414, Level: 8
Points: 1,414, Level: 8 Points: 1,414, Level: 8 Points: 1,414, Level: 8
Brush plate it is!
just to thro some thing else in the mix (1st post bwt) u could go for something like this http://www.nexxia.co.uk/Wall_plate_C...P-803_back.jpg
you wouldn't need to do any terminating as your cables would just plug in to the back.. or u could make ur own as i am doing
billytkid (30-09-2009)
Old 01-10-2009, 2:10 PM   #10
1,404, Level: 8
Points: 1,404, Level: 8 Points: 1,404, Level: 8 Points: 1,404, Level: 8
I'm also looking to run my cables behind the wall and also came across the wall plates from Nexxia Mulitmedia Wall Plates
