Not sure if this is the correct location for this post but......
I have bought a video door phone entry system and wanted some advice on how to wire it as i've never done this before.
It is for 4 flats and has 4 separate handsets and one main door camera.
Firstly here is a pic of the back of the front door console(it also has 4 sockets to plug the handsets into,not in pic) :
this is one of the wires that goes into the console:
This is one of the wires that comes from the handset(to console)
and this is the back of the handset where the above wire plugs into
Each handset has a seperate power adapter:
This is the wiring diagram:
OK, pictures over
I would like to know a few of things
1)On the back of the console there are 4 wires, two black for door open(i wont be using this) and a red and blue which on the wiring diagram say go to 12v DC. How do I wire this back to the mains? Do i need some sort of adapter? Also what type of wire should I use?
2)The cable for the handsets has an extra green wire(5 wires), can i power the handsets from this so I dont need to use the external power supplies? the reason i ask is on the back of the handset on the 4th pic shows D12v.
If I am able to do this would I need to run extra cable aswell as the 4 wire cable I am already running?
3)What is the best way to join my 4 wire cable to the ends of the cable above? Solder something else?
Sorry if this is a bit long winded, but any help would be hugely appreciated
Thanks very much
