3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > TVs > CRT TVs
Latest AVForums Movie Reviews
Zombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray Review
Clash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray Review
Thread Thread Starter Forum Replies Last Post
SKY+ HD Pace HDMI Sony Receiver Flicker Help please I'm going Nuts madmartin Sky HD 89 02-11-2009 9:29 AM
Toshiba 36ZP46P, Colour Problem ? Aletank CRT TVs 2 13-04-2009 3:42 PM
DVD playback problem Breers33 Home Entertainment PCs 7 12-04-2009 9:28 AM
Old 08-04-2009, 5:25 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Sony Trinitron kv-x2552u tuning problem
Does anyone know how to tune the TV with the RM-670?
I recently bought this TV and remote second hand but the remote control is so weird-looking that I cannot work out how to operate it for tuning all the channels.
Please help if you can!
laxime is offline   Reply With Quote
Old 10-04-2009, 6:05 PM   #2 (permalink)
Thanks: Gave 0, Got 6
Re: Sony Trinitron kv-x2552u tuning problem
Its maybe the button that says menu, but is a sony remote or a replacement?
N
never-right is offline   Reply With Quote
Old 10-04-2009, 7:35 PM   #3 (permalink)
hi,
thanks for your reply.
there is no button that says MENU, there is nothing obvious that you'd press on it. i have tried a combination of buttons but to no avail.
it is a sony remote RM670, not a replacement.
any other ideas?
laxime
Old 11-04-2009, 12:28 PM   #4 (permalink)
Thanks: Gave 4, Got 37
My records show that the RM670 is not the correct remote for that model.It should be a RM816.Many Sony remotes will work different models but not all the functions that you require.This often happens when sets are moved to a different area and although they worked ok previously they need retuned to a different transmitter and the problem then shows up.
mechanic is offline   Reply With Quote
Old 12-04-2009, 6:53 PM   #5 (permalink)
Thanks: Gave 2, Got 6
Originally Posted by laxime View Post
Being a TV repair man I can 100% tell you that remote RM-670 will not tune that model TV.
You will need to get the right remote that has a "Menu" button on it as that's the only way to get the TV into tuning mode, try a well known auction site for a used good remote search "Sony RM-831"
The proper remote has 2 sides and slides out of a plastic holder.
Enclosed is a picture of the proper RM-831 you want.
Hope that solves your issue.
TVrepairman000
TVrepairman000 is offline   Reply With Quote
laxime (16-04-2009)
Old 16-04-2009, 4:27 PM   #6 (permalink)
Thanks for your replies.
However, does anyone know how one would tune any TV sony model with the rm670. It is worth a try! I cannot work out any of the non-numeric buttons, and one of those must be right for tuning. I would like to give it a go before throwing the remote away (bought from ebay too!).
Thanks a lot,
laxime
Old 19-04-2009, 3:57 PM   #7 (permalink)
Thanks a lot,
laxime
The RM-670 WILL NEVER tune in your TV.
The only Sony TV's the RM-670 will tune are the ones that had buttons under the front flap, you had to press a button under this flap which bought up a tuning / menu, you could then use the remote (RM-670) to search and store ect, this is why Sony never put the "Menu" button on this remote as TV did not need it.
Later model TV's like your KV-X2552u Sony added the "Menu" button on the remote control and got rid of the button under front flap, proberbly to save money and time.
TVrepairman000
Old 23-04-2009, 7:10 PM   #8 (permalink)
HI again,
I went and bought the model suggested off ebay (rm 831) but it doesn't seem to work on the TV either. In fact, I was able to operate more functions from the RM670. The 831 seems to work, as many of its controls do work, but when I press Menu nothing happens.
Any ideas?
I now have the tv plus two RC and none of them seem to work...
Originally Posted by TVrepairman000 View Post
TVrepairman000
Old 23-04-2009, 10:15 PM   #9 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 131, Got 928
Any ideas?
You need the RM816 as advised earlier in the thread.
JayCee
No help given by PM so please don't ask
JayCee is offline   Reply With Quote
Old 26-04-2009, 12:33 PM   #10 (permalink)
Thanks: Gave 0, Got 15
if menu isnt working, then try the keys under the top flap of the RM670,
they look like an open diamond and closed diamond..
Has been a while since i saw a KVX2552 but it might be the earlier AE1 chassis that didnt use menus.
The TV Engineer is offline   Reply With Quote
Old 27-04-2009, 6:05 PM   #11 (permalink)
I am going to attach two images of the three remote controls I have (two are of either side of the rm831 and the other one is the rm670) to see if anyone out there can advise on what to do this time, and to avoid confusion.
I can find no flap on the rm670 (and nothing like a diamond shape).
I would rather do this before going to buy a new model as the advice so far hasn't solved the issue.
I look forward to any more comments.
Thanks!
Sony Trinitron kv-x2552u tuning problem-img_4001a.jpg   Sony Trinitron kv-x2552u tuning problem-img_4002a.jpg   Sony Trinitron kv-x2552u tuning problem-img_4004a.jpg
kvx2552u, problem, sony, trinitron, tuning
Copyright © 2000-2010 M2N E. & O. E.
