Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > TVs > CRT TVs
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Old 08-05-2003, 5:40 PM   #1 (permalink)
doncorleone
Posts: n/a
S video from tv to laptop
Hi ive just realised that my laptop has an s video port and i know my tv does. Is it possible with the right leads to get the picture from your laptop to transmit onto my tv? If so what does the quality tend to be like?
Old 08-05-2003, 5:43 PM   #2 (permalink)
nathan_silly
Posts: n/a
It's OK. Can't use it for internet/word though- too blurred. Good enough for games/movies. Buy a good quality S-video lead though, a cheap one has lots of video noise, with a quality one there is hardly any noise. If you play movies on the laptop you'll probably get the problem of no movie image on the TV. If so set your primary display as TV and secondary display as laptop LCD. Restart media player on it'll work.
Old 08-05-2003, 5:56 PM   #3 (permalink)
doncorleone
Posts: n/a
'If so set your primary display as TV and secondary display as laptop LCD. Restart media player on it'll work.'
Thanks for the quick reply but how do you do this? Also will it work when playing movies in real one and things? Finally is it better to have s video (laptop) - scart (tv)
Old 08-05-2003, 6:02 PM   #4 (permalink)
nathan_silly
Posts: n/a
Right click on the windows desktop. Select Properties, settings, Advanced. There should be dual head/clone/dual view or something like that (depending on your video card)
It's really annoying you have to switch them over. When the TV is primary, LCD is secondary there is no movie image on the laptop screen. And vice versa. You only need to do this for movies though- for normal desktop use it'll output the same.
Just use a s-video to s-video cable. If you want high quality audio, use digital audio out from your laptop (if it's got one) or purchase one of these (only outputs 2 channel) I've got one myself, cos the headphone output sound awful..
http://cgi.ebay.co.uk/ws/eBayISAPI.d...&category=4786
Old 08-05-2003, 6:12 PM   #5 (permalink)
doncorleone
Posts: n/a
I looked under the advanced settings and couldnt see anything like that.
All ive got is general, adaptor, monitor, troubleshooting and color management
Old 08-05-2003, 6:15 PM   #6 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 97, Got 1,360
Monitor is the tab you need probaly greyed out unless TV is connected, does with my Radeon Mobility card!
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 08-05-2003, 6:19 PM   #7 (permalink)
nathan_silly
Posts: n/a
Just try out plugging it in first- and see if you get the windows desktop for now.
Try updating video card drivers, this might include option to change over, and perhaps a applet to quickly do this.
Old 08-05-2003, 6:35 PM   #8 (permalink)
doncorleone
Posts: n/a
alright cheers
would you count a Ixos XHV403 as being a good enough lead?
Old 08-05-2003, 6:38 PM   #9 (permalink)
nathan_silly
Posts: n/a
Yeah, should be good enough. Don't go over 5M in length though, S-Video is not great for long runs (composite, RF, Component & RGB is much better for long runs)
laptop, video
Copyright © 2000-2010 M2N E. & O. E.
