Toshiba CN32V71... intermittent loss of tuner function
My Toshiba CN32V71 Cinema Series has an intermittent loss of tuner. Using the tv's tuner, and at random it will go to all snow. But when I run the signal from the Panny VCR and use the Panny tuner, it displays properly.
In other words, the Tosh tuner goes out... then I have to click the "TV, ANT 1; ANT 2; VIDEO; COLORSTREAM" selector from the tv's tuner, and use the tuner from the VCR.
I am trying to find out if there is a mechanical internal switch that is dusty or dirty; because it acts up at random almost like a dirty contact somewhere.
I am disabled and it will be hard for me to try and slide the tv out... but if anyone could confirm my thought and tell me if there is indeed a mechanical source selector, then I'd try to find it and spray the contact with contact cleaner.
I hope I explained my problem accurately.... and I hope someone can tell me about my thoughts because my medical situation wont allow a new tv right now.
You're probably wondering... why not use the tuner from the Panasonic VCR. Yes, that's a great option... But my elderly Mom has so much trouble with that remote; I am constantly trying to fix the tv for her.
And the remote that I always used for the Tosh was a easy to use RCA remote bought at Home Depot, of all places... but it works great.
So that's why I'm really hoping that I can somehow try and fix the Toshiba. Can anyone shed some light, maybe?
Thanks very much... Tommy
