Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > TVs > CRT TVs
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Old 13-03-2003, 7:22 PM   #1 (permalink)
Thanks: Gave 14, Got 4
Digital TV resolution
My Philips OnDigital ( aka Freeview) receiver manual states:
Resolution: up to 720x576 pixels.
Are there any other receivers, Sky or Terrestrial with better resolution?
Does anyone transmit in this resolution, e.g. What is the resolution of BBC1? Is it show dependant? Is Eastenders the best pic broadcast?
topmba is offline   Reply With Quote
Old 13-03-2003, 7:47 PM   #2 (permalink)
kevenh's Avatar
Thanks: Gave 5, Got 0
That is the resolution used for PAL frames of video.
The ITU-R 601 spec for PAL resolution is 720x576 non-square pixels covering all the acitve video.
That won't change until we get a high definition standard.
kevenh is offline   Reply With Quote
Old 13-03-2003, 7:48 PM   #3 (permalink)
kevenh's Avatar
It's the difference in compression used by B-Sky-B compared to Freeview that gives the quality differences seen today.
Old 13-03-2003, 8:23 PM   #4 (permalink)
Tasos
Posts: n/a
Arrow ...
So is BSKYB higher resolution than Freeview?...supposing that the set up is working properly with very good signal quality.
Tasos
Old 13-03-2003, 9:16 PM   #5 (permalink)
thanks Kevenh.
As Tasos asks, Which has the better picture?
Is it true that freeview has increased its bandwidth since ITVDigital´s demise and sky is pushing for vhs standard broadcasts to cram more channels in?
Old 13-03-2003, 9:43 PM   #6 (permalink)
kevenh's Avatar
The resolution I'd expect to be the same. What is differeent is compression.
I have Freeview, not Sky, so can't give a fair comparison opinion.
But Freeview is supposed to have fewer channels so they can have a better compression ratio, and it's a fixed allocation. It's hard to tell if there's been any quality increase. The BBC channels always looked better than ITVDigitals extra channels.
Sky uses a variable compression allocation. My parents, and sisters have Sky Digital. It doesn't look any better. Well, worse if anything as they haven't really optomised any settings.
Old 14-03-2003, 9:29 PM   #7 (permalink)
Super Moderator
Thanks: Gave 613, Got 1,102
Re: ...
Tasos
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 15-03-2003, 3:48 AM   #8 (permalink)
MartinImber's Avatar
Thanks: Gave 13, Got 24
I have alway thought that Digital Terrestrial at its best was better than Sky.
Now all channels use a decent bandwidth the quality is actually quite good!
Martin - Sony KDL46W4500, STRDB930, SLHF950 SuperBeta, Pioneer 575, Castle Pembroke, Keep, & Clydes, Pace Twin PVR, BTVision. Sony TRV33 video camera. PS3
MartinImber is offline   Reply With Quote
digital, resolution
Copyright © 2000-2010 M2N E. & O. E.
