Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > TVs > CRT TVs
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Old 19-10-2002, 6:26 AM   #1 (permalink)
"Buzz" on Phillips 9617
Got a Phillips 9617 and despite the peculiar geometry and its tendency to bend the pic when the screen is bright, it's worth it for Pixel Plus! An exceptional picture! But...... I have an annoying BUZZING noise coming from the back of the set. Not a hum, or slight whistle - those we're all used to and expect. This is a Buzz. Now an engineer visited and said that this is perfectly normal. Something to do with cbles or wiring around the tube. Now is that the case? Other Phillips sets I've looked at in stores don't buzz like this. Is there anything that can be done? Any engineers out there who can help?
Sugarhiccup is offline   Reply With Quote
Old 19-10-2002, 9:43 AM   #2 (permalink)
rct
rct's Avatar
Well, my 9617 (32") doesn't buzz at all. Me thinks you should make more of a fuss if it bothers you! The closest person we have to a Philips engineer is Zacabeb... he may even be a Philips engineer! He may have some practical suggestions.
The "peculiar" geometry can largely be cured (mine's good now, aside from a slight downward bend at the bottom LHS) and the bending caused by poor power regulation (common to all mainstream CRTs) can be minimised if the contrast and brightness are set-up carefully.
If you need any help, I'll be glad to give you any info you require.
"In three words I can sum up everything I've learned about life: It goes on." Robert Frost.
Volunteer your PC and fight cancer! http://www.grid.org/projects/cancer/
rct is offline   Reply With Quote
9617, buzz, phillips
Copyright © 2000-2010 M2N E. & O. E.
