Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > TVs > CRT TVs
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Old 18-09-2004, 1:33 PM   #1 (permalink)
Panasonic_Dude
Posts: n/a
Panasonic repair outside warranty?
Ok i have a PG50 with a hum, it's outside the warranty and panny have said send it to a service centre for repair. As this is an accepted design fault with this model am i going to foot the bill and if i do how much am i likely to be charged for (what i'm told) is a very simple job?
Old 18-09-2004, 2:13 PM   #2 (permalink)
Thanks: Gave 67, Got 108
Why not ask the repairers?
Better than giving them a blank cheque!
Tight Git is offline   Reply With Quote
Old 18-09-2004, 8:55 PM   #3 (permalink)
Thanks: Gave 0, Got 5
If this is an accepted design fault you are entitled to have the repair carried out free of charge - are you sure of your facts? You do not specify what the fault is - perhaps this may be a 'well known fault that develops over time' rather than a design fault? regards, yt.
red16v is offline   Reply With Quote
Old 19-09-2004, 9:37 AM   #4 (permalink)
Panasonic_Dude
Posts: n/a
Yes it is Red16v, i refer you to this thread i recently found Link The question remains, am i still entitled to have the tv repaired even if it's outside the warranty?
David
Old 19-09-2004, 4:53 PM   #5 (permalink)
I'm not familiar with this model. I presume from following your thread pointer that this is a reasonably 'old' set now ? If you have been hearing this problem from new then yes you would be entitled to a free repair (arranged by the manufacturer) but if you have been living with it for a number of years (or the problem has only just manifested itself) then I think your case is seriously weakened. regards, yt.
panasonic, repair, warranty
Copyright © 2000-2010 M2N E. & O. E.
