Originally posted by Tesla I almost got this TV but was put off by:
Poor quality stand (sounds like you dont need it)
1 RGB scart (2 scarts in total)
Other than that it is a stunner!
\\Chris |
Yeah the 2 Scarts is really my only concern. I might even go for a second hand (old generation PixelPlus+) Philips to get 3 scarts (2 RGB). Where did you get your Pana from... good value?
Originally posted by rvd48 y u wanna buy that model, it'll give u a bad pixelated picture, y dont do search this forum with that model number? |
I have read the threads and in between a few positive responses. The thing is I have very particular taste and find that comments written in forums rarely reflect my experiences. Maybe thats why I want to buy from a reputable company so I can effectively give it a go and return if I find it's not suitable. I've checked the set out in a shop and was resonably impressed but as you know nothing beats getting it home and trying it out yourself.
The two scart only issue is a problem, particularly the single RGB but I can live with that if the picture is to my liking. The thing is I've found some alternatives, namely Sony and Toshiba (not going to buy another Panasonic after my experience with my current widescreen set) but the price is similar so I was hoping to give PixelPlus+ a go.
Anyone got cheaper then..
