Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > TVs > CRT TVs
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Old 03-01-2004, 5:53 PM   #1 (permalink)
soswin
Posts: n/a
Toshiba 42WH36 convergence prob + interference
I've just received a Toshiba 42WH36 but have 2 problems with it. Firstly the convergence was pretty bad, so I've been trying to adjust it through the menu, however this is proving tricky to get just right. Is it a feature of RPTV's that this can never be spot on?
My 2nd problem is I appear to get interference from BBC2 when watching SKY (via scart) from the TV arial. Goes away when I unplug it. Anyone else had a similar problem?
thanks
Stephen
Old 03-01-2004, 7:00 PM   #2 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 235, Got 770
Not sure about your interference problem but the convergence ought to be manageable.....there is a simple user level convergence menu,and a service level menu also,for the brave hearted.....if you haven't managed to get things right with the user level convergence,and you've only just received the RPTV,I'd strongly suggest getting the supplier to get a Toshiba engineer out to you,to correct the problem,rather than going into the service menu yourself and potentially invalidating your warranty.
...There’s an ocean full of midnight rolling right up to the door ...
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline   Reply With Quote
Old 03-01-2004, 7:33 PM   #3 (permalink)
soswin
Posts: n/a
I'll call them out, see what they say.
thanks
Stephen
Old 04-01-2004, 11:43 AM   #4 (permalink)
search on the forum.
You will find how you can easily fix the convergence in the service menu.
I did it and im very satisfied.
johan
Bolle is offline   Reply With Quote
Old 04-01-2004, 12:34 PM   #5 (permalink)
Super Moderator
alexs2's Avatar
johan
The reason I suggested a call to the suppliers/Toshiba in the first instance is that the RPTV is new,and thus under guarantee which will be invalidated by fiddling around in the service levels.....if this isn't a problem,then as Bolle suggests,a search here will provide all the information you need.
If you do,be sure to write down all of the service level values before making any changes,so at least you have something to revert to if you press the wrong button!
Old 05-01-2004, 10:08 PM   #6 (permalink)
soswin
Posts: n/a
Update: Rang toshiba, they explained the converence needs doing for each picture type (wide / cinema / 4:3 etc...) so I've tried that but it hasnt helped. I've noticed its just the red that goes out of alignment. I have to ring Comet now to ask their advice.
Old 05-01-2004, 10:58 PM   #7 (permalink)
MarkR's Avatar
Thanks: Gave 18, Got 17
Phone them back and tell them that the set needs a service level convergence done in all modes.
When I first got my 42 I tried the simple level convergence and no matter how hard I tried I still could not get the crosses bang on. Since then I have done a service level convergence thanks to Demons instructions and believe me I was stunned when I learnt how easy it was. It really should be in the normal menu.
I agree with Alexs2 that as the set is new get them to do it.
Roses Are Red, Violets are blue, I'm a raving lunatic, HAAAAAAAAHHHH!!!!!
XBL: Mr Maximus 1
MarkR is offline   Reply With Quote
Old 06-01-2004, 10:53 AM   #8 (permalink)
Thanks: Gave 2, Got 10
Re: Toshiba 42WH36 convergence prob + interference
I had a vaguely similar problem with picture crosstalk when watching Sky on External 2.
This was fixed by changing the External2 output to "Monitor" (it was originally set to "TV")
With a better scart lead this shouldn't cause problems but it made a big difference in my case.
If this is the problem however, it doesn't explain why the interference is always from BBC2?
johnjackthom is offline   Reply With Quote
Old 06-01-2004, 12:07 PM   #9 (permalink)
hmsq's Avatar
Thanks: Gave 23, Got 11
just received mine just about 20 minutes ago and the screen is out of the tv frame! Dam it is annoying just on the phone now to comet, or woud it been easier for me to do it and put it back in !
I just thought it could be damaged! So i phoning them, waiting for a response on the phone! We are seriously unlucky with tv second one we buy and its a dud(thirdly counting the replac)
Hope the next one is not like this!
http://www.hugoqueiriga.com/
The travelling dude!
FLICKR ACCOUNT
hmsq is offline   Reply With Quote
Old 06-01-2004, 6:56 PM   #10 (permalink)
soswin
Posts: n/a
Thats cured my interference problem, thanks johnjackthom. I'll get a better scart lead as well as the one I'm using for sky is pretty cheap.
thanks again
Stephen
Old 07-01-2004, 10:11 AM   #11 (permalink)
It took me a while to get the convergence sorted on my 46WH08 but at the time (2 years ago) I found a few helpful hints on entering the service menus by searching this forum.
I would imagine all the Tosh RPTVs have similar adjustments.
Edit: Try a Search by User Name for posts by Demon and you'll find loads of info including how to get into the Service Convergence mode.
Old 14-01-2004, 4:16 PM   #12 (permalink)
soswin
Posts: n/a
Comet have sent someone around and he agreed the convergence wasnt ideal. They are going to send out an engineer. Seems that quite a few of these tv's need the convergence tinkering, toshiba should really make a better job of it at the factory.
Old 14-01-2004, 5:56 PM   #13 (permalink)
Kazman's Avatar
Thanks: Gave 266, Got 107
Angry Arrrgghh!!! 42WH36P giving me problems
Took delivery of the TV yesterday, and found many issues.
I personally managed to get the convergence settings spot on. No problems there.
The issue I came across is that after a few seconds of switching the TV on, I get lines appearing across the entire width of the screen intermittently, like scrambling lines, sometimes the lines cover the entire screen, sometimes the screen entirely clear.
Now it has evolved into the screen blurring out, like the focus has gone.
Very annoyed, engineer should around soon, but it is very frustrating because I was really looking forward to this TV.
Has anybody heard of this or experienced this? Is there anything I can do to fix it?
Kazman is offline   Reply With Quote
Old 14-01-2004, 10:22 PM   #14 (permalink)
General Skanky's Avatar
Thanks: Gave 23, Got 29
On a normal CRT TV, you've described a fault found in a line output transformer. In simple terms, it drives the tube to create a picture. Common faults are poor focus and flyback lines. It could also be the controlling IC for the lopt too.
Not sure on a RPTV, but as it is also CRT in nature, it wouldn't surprise me to find a similair fault.
Guy
Onkyo TX-SR875 B&W MT-30 Panasonic 50PH9 PS3 Sky HD
General Skanky is offline   Reply With Quote
Old 14-01-2004, 11:11 PM   #15 (permalink)
Kazman's Avatar
Well, the issue has now evolved.
The lines now turn into a mass of what can only be described as green sin curves. The convergence of the three colours then seperates slowly, until all three colours are seperated from each other and the colours are portraying the movement on the screen independantly.
The screen then pinches from top to bottom convexing into a horizontal hour glass shape.
I guess the TV is buggered and I got hold of a dud. Hope the engineers call soon, as it is VERY infuriating. I'm hesitant to go into the service menus, but if the engineers do not turn up by Friday, I may have to.
42wh36, convergence, interference, prob, toshiba
Copyright © 2000-2010 M2N E. & O. E.
