3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > TVs > CRT TVs
Latest AVForums Movie Reviews
Vengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray ReviewJulie & Julia Blu-ray Review
Last Action Hero Blu-ray ReviewBlack Dynamite Blu-ray ReviewProphecy - Music From The Motion Picture CD ReviewHarry Potter And The Chamber Of Secrets Blu-ray ReviewBodyguards and Assassins Blu-ray Review
Old 08-12-2003, 11:17 PM   #1 (permalink)
TOSH and Sky+
Just had delivered 32zp38 with 330e DVD and Sky + with good quality QED and IXOS leads. Everything is great...apart from the SKy + picture which is anything but sharp.
DVD playback is crystal clear. Appreciate any suggestions on how to clear up the sky picture.
Fallguy is offline   Reply With Quote
Old 09-12-2003, 1:23 AM   #2 (permalink)
Thanks: Gave 5, Got 7
Does the Sky box go through another box,if it does,try it direct to the TV and have you double checked all connections?
Wayne Moule is offline   Reply With Quote
Old 09-12-2003, 2:23 AM   #3 (permalink)
petebog
Posts: n/a
Sky + known to have soft picture problem. Has been discussed on a different forum
Old 09-12-2003, 7:15 AM   #4 (permalink)
Sky+ goes direct to TV, cables good quality and connections fine. I'm going to play around with the 100hz/progressive scan/normal settings as well as the picture modes to see if that makes a difference.
Old 09-12-2003, 2:15 PM   #5 (permalink)
Thanks: Gave 1, Got 32
just possibly worth checking the SKY+ is outputting RGB???
I have the original SKY+ box and it is sharper then the 'sony' box it replaced.
Demon is offline   Reply With Quote
Old 09-12-2003, 7:51 PM   #6 (permalink)
Ah,100Hz again,that'll be the prob.
My Sky is as sharp as anything else I've got,like DVD and Freeview.
Old 09-12-2003, 9:14 PM   #7 (permalink)
Sky+ is on RGB, I'm trying to decide which setting in scan mode to use. I am not happy with the 100hz, natural seems best.
The settings on M mode as recommended on this forum definitely are better than mode 1 (v bright), 2 (ave) and 3 (dull, but better than 1&2)
Thoughts? What settings are other TOSH users finding best for Sky and DVD?
sky, tosh
Copyright © 2000-2010 M2N E. & O. E.
