Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 12-10-2003, 1:18 PM   #1 (permalink)
Can I please my wife with a few less inches?
I have been looking into buying a 36" CRT (probably Sony) or an even bigger RP TV.
My wife is very concerned about the TV dominating our living room. For the sake of domestic harmony, I might consider getting a 32" CRT instead.
My viewing distance is between 3 and 4 metres - is a 32" big enough for sports viewing at that distance?
I know Loewe do 32" TVs but not 36"s. THey are the Which best buy this month - are they worth the extra dosh?
Thanks for any help.
rickmorley is offline   Reply With Quote
Old 12-10-2003, 3:35 PM   #2 (permalink)
I'm waiting for a Tosh 36zp38 from John Lewis's. Similar size concerns to you, although I did create a cardboard cut-out of the fascia & depth.
Hopefully it won't be too wide (it's narrower than some 28" sets from 12 mths ago. If it is too big though, I should be able to get them to swap it.
Like most things, I suspect it will look big to start with but we'll get used to it after a couple of days.
Best to aim big - otherwise you'll never know what you could have got anway with.
Richard Morris is offline   Reply With Quote
Old 13-10-2003, 12:48 PM   #3 (permalink)
I had the same problem with my spouse. Basically, if it's bigger than the current tv, then it's too big!
I had a heck of a job getting clearance to upgrade from a 25'' 4:3 to 32'' widescreen. Eventually she agreed to the purchase when she saw the proposed upgrade - a Loewe Aconda.
For a few days she complained that it was 'quite imposing', but within a week she was singing it's praises. Now she wouldn't settle for anything less.
She'll come around - I promise.
ianbe is offline   Reply With Quote
Old 13-10-2003, 5:27 PM   #4 (permalink)
DoogyDawg's Avatar
sorry but just had to jump in on this one to say, thats the best subject line I have seen in a long time, well done matey, very funny
DoogyDawg is offline   Reply With Quote
inches, wife
