Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 11-10-2003, 5:50 PM   #1 (permalink)
Thanks: Gave 3, Got 14
Toshiba PF2 EXT question
Hi guys,
On my old Sony I could lable each AV chan i.e AV1=Movie,AV2=Xbox etc
Do I have to go into the service screen to do this?, as theres no option in the menus
Peace.
bboy-mass is offline   Reply With Quote
Old 11-10-2003, 7:10 PM   #2 (permalink)
SimonO's Avatar
Thanks: Gave 49, Got 59
No...
Panasonic TH-50PF10EK | Thomson Sky+HD 1TB | Oppo BDP-83R | Sony PS3 60GB | Nintendo Wii | Sonos CR200/ZP90 | Onkyo PR-SC886 | Rotel RB-1562 | Blue Sky SAT 6.5 | B&W DM600 S3 | Velodyne SPL-1200R | Philips TSU9600/RFX9600
SimonO is offline   Reply With Quote
Old 12-10-2003, 12:15 AM   #3 (permalink)
Thanks: Gave 1, Got 32
my 51wh36 which I believe has similar menus.. (orange and grey, with the added 'PROGRESS' picture mode)... can label the AV Channels..
MENU->SETUP->MANUAL SETTING this then allows all the AV to be labelled... maybe not the same as the PF2.. but Toshiba only use a small number of core chassis, so it may be the same...
Demon is offline   Reply With Quote
ext, pf2, question, toshiba
