Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 11-10-2003, 1:22 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Speaker Grill on Tos 42WH36
Hi, Does anybody know how to get the speaker grill off the front of the toshiba 42wh36 tv ? Is it even possible ?
I need to get the front of so I can clean the inside of the screen. I've heard that you need to get the speaker grill off 1st, but theres isnt any screws at the bottom of the screen, so do you just have to pull it off some how ?
thanks in advance
Mart...
toadie is offline   Reply With Quote
Old 11-10-2003, 1:35 PM   #2 (permalink)
Thanks: Gave 1, Got 3
hi,
If you want too know anything on the tosh wh36 serie,you better ask demon.
He has the 51 inch,and has a topic on this forum off his tips and tweaks
On this topic he shows you how to pull the speakergrill off.
Mvrg,
Raymen
mvrg.raymen
raymen is offline   Reply With Quote
Old 11-10-2003, 1:38 PM   #3 (permalink)
yes ive seen it, that grill is cloth, and mine is plastic, im sure mine isnt going to come off !
ta
mart
Old 11-10-2003, 5:38 PM   #4 (permalink)
no probs, got it off, was easy ! thanks !
42wh36, grill, speaker, tos
