Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Play TV Part 2 BenchyUK PS3 Media & Streaming 395 Today 12:48 PM
The Buzz Quiz TV - Play & Help Chrisuk28 PS3 Games 616 16-10-2009 9:19 AM
If I was to go and get a new TV today, which should it be ? dUnKle Xbox 360 73 31-03-2009 12:51 PM
Using a Windows laptop to control a Mac mini, can it be done? danwalton Mac Hardware, OS and Software 15 31-03-2009 11:28 AM
Old 30-03-2009, 5:46 PM   #1 (permalink)
Laptop to CRT TV
I want to connect my laptop (Samsung NC10) to my PHILIPS FLAT SCREEN CRT TV ~5 years old.
The only connections my TV have are the RCA.
Will a simple VGA to RCA cable work?
I've been reading about this and came across some people needing a scan converter.
Are there anyway to find out if I need one?
ym_21 is offline   Reply With Quote
Old 03-04-2009, 12:52 PM   #2 (permalink)
Thanks: Gave 82, Got 58
Re: Laptop to CRT TV
Welcome to the Forum!
vga/hdmi to scart/s-video
aekostas is offline   Reply With Quote
Old 04-04-2009, 12:23 AM   #3 (permalink)
NeoBlade's Avatar
Thanks: Gave 0, Got 2
Welcome to the forums ^_^ First up, great decision on the NC10! I have one, upgraded it to 2GB and running Windows 7 on it atm.
As for connecting it up to your CRT TV, the easiest option would be S-Video but the image is awful... You might have to invest in a VGA > RGB Scart converter if you are serious about using it rather often and have a decent image at the end of it.
NeoBlade is offline   Reply With Quote
Old 06-04-2009, 12:32 AM   #4 (permalink)
clemenzina's Avatar
Thanks: Gave 70, Got 60
I know it's not laptop to TV, but I've just connected up a Topfield PVR to my CRT TV via S-video and the picture is very good.
clemenzina
clemenzina is offline   Reply With Quote
Old 18-04-2009, 9:47 PM   #5 (permalink)
tvbox's Avatar
Thanks: Gave 664, Got 156
do you have a s video port on your laptop? if so then it will be easy because nearly all the tvs have s video but do check your tv before you get the cable.
tvbox is offline   Reply With Quote
crt, laptop
