Originally Posted by fallenangle Later when I had the money my choice of dedicated gaming TV (a Sony WEGA) was significantly influenced by the fact it had manual RGB SCART. But I discovered that even that sometimes wouldn't fully re-centre some games and the geometry is **** too. |
Yes my old Sony TV shifts the picture over to the right when it's in 'proper' RGB mode, but you have to sometimes manually select it from the remote by pushing the input button again.
I agree the geometry leaves a lot to be desired on Sony TV's especially widescreen models, but the factory service mode settings are always a bit iffy and can do with adjusting if you know what you are doing.
I also have an old Philips CM-8833 monitor that's just perfect for retro gaming. It's around the same size as a portable TV, but gives a much sharper picture, and the geometry is excellent.
