Originally Posted by Tel boy
....The DFS module in this TV is the MDFS02A version, does anyone know if Toshiba will supply one FOC like they do with the MDFS03 module that is fitted to the 36ZP38?
Cheers.
Well I contacted Toshiba & they were very helpful, however they say that my model of TV (32ZT29B) did not have widespread problems with the DFS module so they do not supply a replacement free of charge
Paying for a new module wasn’t an option
I know there’s a company that will re flow defective modules but as I wasn’t 100% sure if the module was the sole cause of the fault I didn’t wasn’t to risk having this done as the money would be wiser spent put towards a new TV.
So considering all of the above & the fact the TV is probably only worth about £63p these days I decided to remove the module myself & have a go at re flowing it…if it didn’t work the TV was going in the bin...a "Destructive fix" as I like to call it (It will either end up fixed or f***ed)
So I fired up the soldering iron & got the DFS module out of the TV. On the bench using a bench magnifier I couldn't’t see any obvious dry joints in the module, however the legs of the IC’s are very small so a bad joint would be hard to spot unless you had better magnification which I didn’t, so I set about re soldering all of the legs….30 minutes & a few choice swear words later I had managed it.
I re fitted the module to the TV….Happy days, it’s fixed
Well, it’s been fine since Thursday so I’ll just keep my fingers crossed it keeps working
Cheers.
