Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
For Sale : Optoma (16:9) 84" PJ Screen MikeyV TV and Projector Classified Adverts 18 09-06-2009 12:16 PM
iphone 3G to Sony TDM-IP50 DM port / HDMI Help no1.scribbler Portable Music (MP3, iPod etc.) 8 21-05-2009 7:51 PM
Need help with getting into sony speakers! skippynz Speakers 5 17-03-2009 1:32 PM
Sony RDR-HXD995 problem? Peter54 DVD and Blu-ray Recorders, Recording and Media 24 16-03-2009 1:50 PM
Old 16-03-2009, 1:59 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Sony KV-25F1U...Unable to remove CH number from screen
Hi everyone.
Please help somebody..this is driving me bonkers!!
On my Sony KV-25F1U TV I just cannot remove the green channel number from the right hand side of the screen. Think i've accidently knocked one of the buttons on the remote. Tried eveything, but with having no user manual I don't know which one it is. I'm reluctant to press any buttons on the tv itself for fear that i'll mess all the channels up. Would be far easier if I did have the manual, but for the life of me I just CAN'T get hold of one, and i'm certainly not prepared to pay over £14 for a PDF file.
Grateful of ANY replies.
Thanks,
Geoff
geoff4799 is offline   Reply With Quote
Old 16-03-2009, 2:25 PM   #2 (permalink)
Chris Muriel's Avatar
Thanks: Gave 185, Got 379
Re: Sony KV-25F1U...Unable to remove CH number from screen
Try holding down any "Info" or "i" button for a few seconds; on many sets this toggles the setting from always displayed to just displayed for a few seconds after channel switching.
Chris Muriel, Manchester
Chris Muriel is offline   Reply With Quote
Old 16-03-2009, 3:01 PM   #3 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,199
Although for the 21" it may be the same Televisions and ProjectorsÂ*|Â*CRT TVÂ*|Â* KV-21FT1UÂ*|Â*Sony Europe Customer Support Portal
Andy98765 is offline   Reply With Quote
Old 16-03-2009, 3:15 PM   #4 (permalink)
No tried all this i'm afraid Chris..many thanks for your speedy reply though.
Geoff.
Old 16-03-2009, 3:17 PM   #5 (permalink)
Originally Posted by Andy98765 View Post
No not the same at all Andy..thanks for suggesting though.
Geoff
Old 16-03-2009, 3:19 PM   #6 (permalink)
Thanks: Gave 4, Got 36
Check your remote for a small square (looking like a little telly)with a plus symbol inside it.That clears the channel number off the screen.Its normally close to the teletext keys.
mechanic is offline   Reply With Quote
Old 16-03-2009, 3:29 PM   #7 (permalink)
No symbol like that on remote. But tried every one of the buttons..with not only a quick press but also kept pressing them for a while.
Cheers.
Old 16-03-2009, 11:57 PM   #8 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 856
Do you have the original remote that was supplied with the set...RM862?
If you do there are 2 rows of buttons along the top to control Sony VCRs.
Immediately underneath the Pause button is the i+ button which enables/disables the on-screen display.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
geoff4799 (17-03-2009)
Old 17-03-2009, 9:39 AM   #9 (permalink)
JayCee you are an absolute STAR!!!!!!!!!I don't BELIEVE the blastered thing has actually gone, after a fortnight! Yes I have the original remote, but I HAD tried this button MANY times with the all the rest of them. So I continually pressed this one again for a good while and HEY PRESTO!..must have been sticking somewhat before. THANK YOU SO SO MUCH.
Geoff.
Old 17-03-2009, 10:43 AM   #10 (permalink)
I'm glad the mystery is solved (thanks to Jaycee).
When I said "Info" or "i" , I would not have have guessed at "i+" - but I guess I was close.
kv-25f1u, kv25f1uunable, number, remove, screen, sony
