Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Sony BDP-S550 Region B UK owners thread. - PART 2 paulst10 Blu-ray Players 799 18-11-2009 4:42 PM
Sony BDP-S5000ES Region B UK Owners Thread - Pt II kingfats Blu-ray Players 378 28-10-2009 7:25 PM
Harmony Remote Multiregion DVD Hack for Panasonic, Pioneer & Sony Blu-ray's Part 3 AV Junkie Blu-ray Players 1067 04-04-2009 5:57 AM
Panasonic Viera G10 Series 50" TX-P50G10 HD 1080p Plasma or sony 52" HD1080p LCD teapot1971 Plasma Televisions 9 14-03-2009 2:10 PM
sony dvd dcr 110 camcorder tobydog1961 Camcorders and Video Editing 1 14-03-2009 12:25 AM
Old 14-03-2009, 12:28 AM   #1 (permalink)
Thanks: Gave 8, Got 1
sony trinitron fault. pic on/off
i have an 9 year old Sony trinitron.
recently developed a fault
the screen will go black for a few seconds then the picture returns. there is still sound when this happens
would this cost a lot to repair?
seems a shame to dump it
thanks
cruiser27 is offline   Reply With Quote
Old 14-03-2009, 9:22 AM   #2 (permalink)
Thanks: Gave 53, Got 94
Re: sony trinitron fault. pic on/off
Sounds like it might be a dry solder joint. not huge job to fix it.
Also, Trinitron is the name Sony gave to their tubes and is not the model number. Sony TV model numbers back in the mid-late 90's started with a K (i used to work in a sony centre in a past life)
Sheepking is offline   Reply With Quote
cruiser27 (14-03-2009)
Old 14-03-2009, 3:28 PM   #3 (permalink)
thanks. yeah its a KV-29 FX 11U
so worth calling the repair man then you think?
Old 14-03-2009, 8:05 PM   #4 (permalink)
If its a quick solder job then i'd think so (as long as you're still happy with the picture)
It could be a good excuse to upgrade to a shiny new widescreen plasma though
Old 17-05-2009, 5:26 PM   #5 (permalink)
I've got the same problem but it seems to clear up after the TV's been on a while. This time to no flicker though seems to be getting longer...
Could it be a dry solder? And is it something one could attempt to sort?
Any ideas welcome.
midiwife is offline   Reply With Quote
Old 17-05-2009, 6:19 PM   #6 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
No, dry joints aren't temperature sensitive.
Sounds like a faulty component.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 17-05-2009, 6:40 PM   #7 (permalink)
Cheers for the info JayCee.
I'll look out for a replacement set then as the colour's also going a bit.
Old 17-05-2009, 7:56 PM   #8 (permalink)
Thanks: Gave 0, Got 5
Almost certainly a dry joint, having been a Sony engineer for many years i'll bet my wife on it !
mikejjj is offline   Reply With Quote
Old 18-05-2009, 9:48 AM   #9 (permalink)
But... how would I set about trying to mend it??? How would I even find it? And, what about the colour business? I could well end up being more cost effective to source a replacement. But, I don't like widescreens so replacements are likely to be of around the same vintage... possibly with similar problems.
Old 18-05-2009, 11:56 AM   #10 (permalink)
Thanks: Gave 0, Got 24
On the Sony KV series you can access the service menu via the remote with a secret combination of buttons.
This gives you access tot tweak the geometry, the colour settings and the individual colour guns. Also you can mess around with sound and look at service info.
I don't know if these TVs have a gating mode when there is a fault but many older TVs used to gate on and off (via the PSU) if they detected a fault.
This made the picture turn on and off and it was done like this to prevent the TV from damaging itself further during a fault.
If it's had a useful life I'd bin it unless you can repair it yourself. Repairing CRTs can be hazardous (electric shock hazard).
Otherwise you are going to end up paying a huge hourly repair bill plus parts for a TV that is beyond its design lifetime.
Poor solder joints can be VERY temperature sensitive. Especially if the temperature change is rapid and there are parts of a CRT TV where this is the case.
However, it could equally be a component, eg a capacitor breaking down.
Or it could be damp/dust causing breakdown.
Chelsea_Fan is offline   Reply With Quote
Old 18-05-2009, 3:18 PM   #11 (permalink)
Conspicuous Member
JayCee's Avatar
In my 40 odd years of repairing all types and makes of TVs I think I've accumulated a wee bit of knowledge and experience
The OP stated...
"I've got the same problem but it seems to clear up after the TV's been on a while. This time to no flicker though seems to be getting longer...
Could it be a dry solder?"
This is more than likely to be a low emission crt or a high esr capacitor probably in the psu or frame output stage....the giveaway part is "it seems to clear up after the TV's been on a while".
I reiterate this is not likely to be a dry joint in this case.
JayCee
Old 18-05-2009, 5:48 PM   #12 (permalink)
The OP stated...
Fair enough, you sound like you know a thing or two about TVs
However, the above isn't strictly true. I also have an electronics background (not TVs) and I was making the general point that I've seen plenty of poor solder joints respond to temperature cycling. Eg putting circuitboards in a Thermotron chamber and cycling them from +50degC to -20degC and back a few times is a great way to find components that aren't soldered very well.
But that's on new boards. I guess the collapsing TV picture problem would have more likely shown up sooner if it was a poor solder joint rather than 9 years down the line.
fault, fault or problem, on or off, pic, sony, sony trinitron 32, trinitron
