I have just purchased a 32dx150 which when properly set i will post a full report,however I have a connection question.
I have a sky box that I watch everything through therefore do i ignore the digital input for my aerial at the back of the tv and simply run a scart and rf cable from sky box to tv with the aerial cable as now going into my sky box.
Or is there a way of using the tv digital tuner for watching sky thru a box.
Can you tell me if your set has a loud buzzing noise enough to disturb your viewing?
Also is there any distortion in the corners of the screen when daylight is shining on it?
Appreciate your answers on these as I've had to return two Toshs due to these probs and spotted more than one Sony with the screen problem in currys/comet etc.
Really like the look of your set but have yet to see it in the flesh.
you should just connect the sky box using the scart sockets at the back and then you can have the best of both worlds.
I am told that the digital picture is far superior to the sky one, so let us know.
I bought the same TV a couple of months ago, I had to get the first one changed due to geometry problems. The new one that I have has a slight blue discolouration on the top left hand corner that lasts for roughly the first hour of operation, each time it is switched on from cold.
Thanks for the replies to date,at the moment the set does not buzz so thats a good sign.
However further to the reply regarding simply connect the sky box using scarts does that mean that the tv aeriel i should be putting into the digital point at the back of the tv? and not in the sky box.
sorry to be a pain but im after best possible quality.
Do you mean distortion of the pic. If so that's a geometry issue and every set is different. If you mean slight distortion/indentations on the aperture grill every sony I've had had this in places. It never really affected picture though and you could only really see it in certain lights when the tv was off.
For best picture remove the Sky box and use the DTTV tuner
__________________ Martin - Sony KDL46W4500, STRDB930, SLHF950 SuperBeta, Pioneer 575, Castle Pembroke, Keep, & Clydes, Pace Twin PVR, BTVision. Sony TRV33 video camera. PS3
Thanks very much for the replies will try out connections tonight and then post.
However if my tv aerial goes into the digital point at the back of the tv and not the sky box am i right in thinking to get sky i only need to connect the sky box to the tv with scart and rf lead and use av 1.
In terms of the reply remove the sky box then by doing this how do i get sky?
