Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 09-09-2003, 12:49 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Philips 32PW9595 - Superzoom
I've only had this set a couple of days and am pretty pleased with it. I've followed a few Philips threads on this forum and managed to get a picture I'm happy with, but have a question about the picture format, and in particular, superzoom.
My input is sky digital, so I'd like the picture to be widescreen for the majority of the time and autoswitch to 4:3 when appropriate, as dictated by the signal being received. The set has different ideas though and is always mad keen to set the picture to SuperZoom, even when the autopicture setting is set to off.
All I want is the telly to be in the right format for the programme, with the default being widescreen. Can anyone help? Please?
douglasgrant is offline   Reply With Quote
Old 10-09-2003, 10:04 AM   #2 (permalink)
HowieC's Avatar
Thanks: Gave 0, Got 3
Set your sky box to a channel you know is 4:3 (eg Sky News) and then set your TV to 4:3. You should now find that the set will switch automatically between 4:3 & 16:9 as required.
HowieC is offline   Reply With Quote
Old 10-09-2003, 11:27 AM   #3 (permalink)
Thanks HowieC
I'll try this tonight. Out of interest, does the autoformat setting in the setup menu need to be 'on' for this to work?
Also, will these setting remain if I switch the set off?
Old 10-09-2003, 1:46 PM   #4 (permalink)
HowieC's Avatar
I suggest leaving autoformat off, and yes it should remember.
Old 10-09-2003, 11:39 PM   #5 (permalink)
Hi - I have a Philips 28PW9308 which also has auto format and I too have been frustrated with this mode and it wanting to super zoom 4:3 pictures and even zooming some widescreen sources from my Sky Digibox.
Seeing it mentioned that you can "switch off" auto format in the setup menu, how do you do this? I have been right through the menu's including setup and cannot find an option to do this?
Please post how here - thanks!
PeterL is offline   Reply With Quote
Old 11-09-2003, 11:52 AM   #6 (permalink)
Lux
Lux's Avatar
on my 8807 it is the stop and play button pressed at the same time and then to setup at teh bottom it saysautformat.
I have similar problems with mine. I hate superzoom. but noticed that when you manually set the zoom to 16:9 or wide or whatever that the TV will remember it when you switch it on the next time. and also apply it to other channels, even when autoformat is on.
And How come that when I have a TV braodcast in 2.35:1 it zooms in to 16:9 but then vertically stretches the picture??
doesn't really bother me though as I only watch the news and DVDs
Pioneer PDP-428XD, PlayStation 3 (EU), Toshiba HD-EP35, Pioneer DV-600AV (MR), Denon 1905, 6 Canton LE 50, Centre Canton LE 55 speakers and Canton AS 22 SC subwoofer, Scorpion Cables, QED and Oehlbach cabling and still some DVDs
Lux is offline   Reply With Quote
32pw9595, philips, superzoom
