| 36" recommendation required
I'm after a 36" TV and have been looking at the Toshiba 36ZD26B. The set seemed ideal, particularly with the stand that covered the DVD, amp, etc (keeps the girlfriend happy!). The problem with this set appears to be that it can't support PAL component video and there have been some comments about vertical lines on the sides of the pictures. Panasonic seem to make a good set too however I'm not sure it will fit a DVD, SKY+ and a Pioneer 2011 amp underneath. Sony sets don't have any prog scan capability.
I'm not worried about the sound capbilities of the set I'm just after the best 36" picture.
Any suggestions on the most suitable set would be appreciated.]
