Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 08-09-2003, 11:38 AM   #1 (permalink)
kwangomango's Avatar
Thanks: Gave 6, Got 19
Static crackle on channel change
For a while i have noticed that when i change channel on my Loewe Mimo, there is a brief but audible static crackle coming from within the set. This doen't really bother me but i am now noticing it during normally viewing. Like on a channel change, it happens whenever the picture changes from something relatively bright to a dark on a full black screen. Depending on the difference in brightness of the image between the transition, sometimes it happens and others not. I thought that it might cure itself as the set settled down but it has not.
Any ideas?
kwangomango is offline   Reply With Quote
Old 08-09-2003, 12:54 PM   #2 (permalink)
I get exactly the same thing happening on my MIMO too. Any transition from relatively light to black will cause it, very similar to the sound it makes when firing up. This also used to happen on my old Philips too, although to a much lesser extent.
I think it's probably something we'll have to live with.
Dazed is offline   Reply With Quote
Old 09-09-2003, 9:08 AM   #3 (permalink)
Pleased!? to hear that i am not the only one. Would be good to here from any other owners who are experiencing this.
Old 13-12-2003, 6:13 PM   #4 (permalink)
Get static sound from my Mimo 28 nearly all the time now - started off occasional now very annoying. I will be calling for a replacement soon
stevod is offline   Reply With Quote
change, channel, crackle, static
