Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 27-07-2003, 6:04 PM   #1 (permalink)
pclarke
Posts: n/a
Panasonic PS1 - Easy one hopefully
I have just purchsed the Panasonic 28PS1 from JL (price match) and I am very pleased with it. I have been down the 100hz route before and the pictures just cannot compete with this Panasonic IMO. Geometry is very good, no inpurities obvious and no vertical banding
HOWEVER, is there any way of having two picture settings, one for analoge pictures and another for RGB. The brightness level on RGB needs to be turned down, but looks fine on normal TV. Therefore, when watching DVDs I need to keep changing the picture settings. Minor but still annoying. Service Menu perhaps???
I hope someone has the answer.
THANKS
Old 27-07-2003, 7:13 PM   #2 (permalink)
fatbob's Avatar
I don't own one of these sets, so I can't be certain, but it's highly unlikely that your tv will allow for different settings for different inputs.
I have components connected to my tv through RGB, S-video and composite, so I know exactly what you mean. I have optimised my settings for RGB, and find that these settings aren't ideal for the other inputs. I have to tweak my settings a little whenever I watch anything other than RGB, but luckily about 80% of my viewing is RGB (dvd and a digibox).
The only (non plasma) tv that I know of that allows for different settings for each input is the JVC HV32D25.
Sorry I can't be of much help.
Bob.
fatbob is offline   Reply With Quote
Old 27-07-2003, 10:21 PM   #3 (permalink)
Joe Pineapples's Avatar
Thanks: Gave 96, Got 47
the Panasonic PD30 also does it apparently
Joe Pineapples is offline   Reply With Quote
Old 28-07-2003, 12:35 AM   #4 (permalink)
ganda
Posts: n/a
hey m8, how much did you pay for this tele and whats JL?
Old 28-07-2003, 2:50 AM   #5 (permalink)
Thanks: Gave 4, Got 9
Re: Panasonic PS1 - Easy one hopefully
You sure about this ?, coz every Panasonic CRT I've seen is extremely bad in the vertical bending/banding department.
Jimmi is offline   Reply With Quote
Old 28-07-2003, 8:56 AM   #6 (permalink)
pclarke
Posts: n/a
The geometry on the TV is good. There is a slight bend to top right but very slight. Used the THX included with T2. Sound is ok but intend to get home cinema seperates soon No purity problems, put a white screen on and no patches!!!
Got the TV from JL in Peterbough for £390. Excellent service and a thoroughly enjoyable buying experience.
Thought about splashing out more but I don't think the money would have bought me a better picture. I just can't get used to 100hz, I tried but failed. Every TV will have a fault or ten, but you just have to find one you can live with.
Thanks for all the responses.
Any suggestions for the surround sound amp and speakers?
Old 28-07-2003, 8:57 AM   #7 (permalink)
pclarke
Posts: n/a
JL = John Lewis by the way
Old 28-07-2003, 4:30 PM   #8 (permalink)
Well I looked at the PS1 today and it did appear to have reasonable geometry. Strangely enough though the PS12 (which should be a better model) had poorer regulation and geometry.
Does the PS1 have geomagnetic correction (tilt control) ?.
I couldn't find it on the menu but found it on the PS12, so I don't know if the PS1 has it.
The PS range also doesn't appear to have anyway of dealing with off screen subtitles (IE no option to gradually move the screen upwards), which seems od for a TV set of this price.
Old 28-07-2003, 9:20 PM   #9 (permalink)
pclarke
Posts: n/a
The TV does have a tilt control. Can only select it using the F key on the TV.
I also looked at the PS12 and was very disappointed. The TV does not have a way to nudge the picture up or down but a small price to pay for what is a very good picture.
I also looked at the Philips 6506 and JVC R25. The JVC has no tilt control (28") while the geometry on the Philips is pants.
Happy shopping
Old 28-07-2003, 10:13 PM   #10 (permalink)
ganda
Posts: n/a
pclarke m8
i want to buy the same tele as you from jl
pls tellme the price match details and how i can order, if its online, web addy pls
no jl store near me
emil is - luki786@hotmail.com
thanks m8
Old 29-07-2003, 8:54 AM   #11 (permalink)
pclarke
Posts: n/a
Ganda,
I price matched with techtonics.com. Phone your nearest JL store, mine was Peterborough. They were a bit shocked at the price but obliged all the same.
They all price match techtronics as they have a shop in Peterborough. Takes a few days for the letter from the under sales dept to come through. I then phoned the JL store back with my credit card and 'bobs your uncle'. TV delivered to me by a professional two man band in a shiny JL truck.
5 Year guaranteeto boot
Old 04-08-2003, 7:20 AM   #12 (permalink)
Thanks: Gave 1, Got 1
pclarke - even though you got JL to price match Techtronics, did they still give you the Freeview box?
I just got JL Watford to price match them, but they said they wouldn't give me the box!
morettat is offline   Reply With Quote
Old 06-08-2003, 12:33 AM   #13 (permalink)
we bought the ps1 from JL Watford (NO price match) for £439 and got a free panasonic freeview box. special deal about 2 weeks ago...
unfortunately not on their website, but at that price just take a small van or large hatchback and drive, you'll still be better off. i checked "what video" magazine and couldn't get close to that price
D'OH!
ellie666 is offline   Reply With Quote
Old 08-08-2003, 6:49 PM   #14 (permalink)
Why not just give Techtronics the support they deserve for giving the best price? Is their service pants or something? Please tell me if so, I'm about to buy a PS1 from them! Unless you folks think I'd be better off with a Thomson 28WH203S - can't find anywhere that sells that though, just seen rave review in What Video.
Any thoughts?
Cheers.
Jamp is offline   Reply With Quote
Old 09-08-2003, 10:35 AM   #15 (permalink)
pclarke
Posts: n/a
I don't think there is anything wrong with Techtronics. I went to JL as I got the PS1 for £378 including a five year warrenty and a free digi box. The service at JL has been top notch too.
No contest really!!!
easy, panasonic, ps1
