20-06-2003, 6:33 PM
#1 (permalink)
| | Member
Thanks: Gave 8, Got 1 | can I convert a PAL-B/G signal to a PAL-I signal?
Sorry if this sounds abit mad.
Is there any way you can convert a PAL-B/G signal to a PAL-I signal ? Is there a box that can be purchased that can do this?
Thanks for any info.....
20-06-2003, 8:29 PM
#2 (permalink)
| | Member
Thanks: Gave 1, Got 45 |
What exactly are you trying to do?
If you're trying to use a Euro video recorder with a UK TV and find the sound doesn't work when connected via the aerial lead, then using a scart lead will sort out the problem.
If it's using a UK tv in Europe then the TV either needs modifying (if possible at reasonable cost) then again, using a Euro video via scart will allow the video to 'decode' the correct sound and vision and pass it through to the TV via the scart.
__________________ Any information given by Orbitalzone should be considered unreliable, innaccurate, questionable and probably down right wrong. Please disregard all information and destroy Immediately. |
21-06-2003, 8:27 AM
#3 (permalink)
| | Member
Thank you for your reply. Quote: Originally posted by Orbitalzone What exactly are you trying to do?
If you're trying to use a Euro video recorder with a UK TV and find the sound doesn't work when connected via the aerial lead, then using a scart lead will sort out the problem. | Yes, this is what i'm trying to do.
Do you know if I use a UK digital Sky receiver with a scart lead with a Euro video recorder or a Euro DVD recorder would I be able to record sound and picture OK from the UK digital Sky receiver ?
Thanks for the info.
21-06-2003, 8:46 AM
#4 (permalink)
| | Senior Member
Thanks: Gave 51, Got 480 | Quote: Originally posted by Duster
Do you know if I use a UK digital Sky receiver with a scart lead with a Euro video recorder or a Euro DVD recorder would I be able to record sound and picture OK from the UK digital Sky receiver? | Yes this will work fine. The main difference between PAL B/G and PAL is the sound carrier spacing which only matters if you are using it via RF, i.e. to receive off air broadcasts or using the RF output to feed a UK TV.
21-06-2003, 2:40 PM
#5 (permalink)
| | Member
Thanks guys, thats great help |
12-05-2009, 10:54 AM
#6 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: can I convert a PAL-B/G signal to a PAL-I signal? Quote:
Originally Posted by Orbitalzone If it's using a UK tv in Europe then the TV either needs modifying (if possible at reasonable cost) then again, using a Euro video via scart will allow the video to 'decode' the correct sound and vision and pass it through to the TV via the scart. | I am interested in the modification aspect. What needs to be modified? Is changing the tuners enough? What components needs to be changed?
12-05-2009, 5:17 PM
#7 (permalink)
| | Conspicuous Member
Thanks: Gave 120, Got 859 | Re: can I convert a PAL-B/G signal to a PAL-I signal?
Terry, don't know if you're aware the post you're replying to is almost 6 yrs old.
Things have moved on a bit since then.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
13-05-2009, 9:45 AM
#8 (permalink)
| | New Member
You are right Jaycee and yes it's a bit old but just in case someone has a solution, you know.
13-05-2009, 6:42 PM
#9 (permalink)
| | Conspicuous Member
Thanks: Gave 120, Got 859 | Re: can I convert a PAL-B/G signal to a PAL-I signal? Quote:
Originally Posted by terry25 You are right Jaycee and yes it's a bit old but just in case someone has a solution, you know. | Years ago you would change a couple of coils or xtals but some modern sets can be changed by an adjustment to software within the service menu.
If you're asking about a particular model you need to provide the make and model no.
15-05-2009, 8:48 PM
#10 (permalink)
| | Member
Thanks: Gave 1, Got 45 | Re: can I convert a PAL-B/G signal to a PAL-I signal?
Wow a blast from the past!
I suspect many modern TV's have the ability to switch to UK or Euro PAL either as a user menu tuning option or a hidden service menu... for example many (if not all) recent Sony LCD's ask which country you're using it in and sets the settings accordingly (PAL I for UK, SECAM for France or whatever)
Older TV's needed some hardware modifications and often they never worked as well as a proper PAL BG or PAL I version (the sound would be thin and tinny)
28-05-2009, 10:57 AM
#11 (permalink)
| | Member
Thanks: Gave 4, Got 65 | Re: can I convert a PAL-B/G signal to a PAL-I signal?
I was asked to look at a toshiba portable because no sound just a hiss.
I found the set had somehow switched to B/G and D/K but no system I in the menu and originally only had system I and no B/G D/K.
Looking at the service manual didn't help either so it was left as it worked ok via the scart.
Terry why do you want to know this info.
18-06-2009, 10:20 AM
#12 (permalink)
| | New Member
Thanks: Gave 1, Got 0 | Panasonic TX-28PL10?
Hi all,
I have an old Panasonic TX-28PL10 UK standard TV which I would ideally like to convert to PAL B/G for use over here in Portugal. I can't find a free service manual online so I don't know if there's an accessible parameter somewhere to set the PAL standard of whether it's a tuner hardware change. Seems a pity to junk the TV but I can't even give it to charity without getting the sound back.
Any input gratefully received.
GRC
__________________ See it all, done it all, can't remember most of it ... |
18-06-2009, 10:32 AM
#13 (permalink)
| | Member
Thanks: Gave 9, Got 48 | Re: can I convert a PAL-B/G signal to a PAL-I signal?
I think that set uses the Euro4H chassis, so you could try finding the manual for that. As previously suggested, you'd still be better off connecting a digital TV box (cable, satellite or terrestrial) to the SCART instead.
18-06-2009, 11:16 AM
#14 (permalink)
| | New Member
Thanks: Gave 1, Got 0 | Re: can I convert a PAL-B/G signal to a PAL-I signal? Quote:
Originally Posted by NST I think that set uses the Euro4H chassis, so you could try finding the manual for that. | Correct and Thanks given - it does use the Euro4H chassis and I found a TX-28LB10F service manual (same chassis) online but can see no mention of changing the receiving system. Not sure if my TX-28PL10 has significant differences to LB10 (apart from widescreen & cosmetics). Quote:
Originally Posted by NST As previously suggested, you'd still be better off connecting a digital TV box (cable, satellite or terrestrial) to the SCART instead. | Which is exactly what we did (Sky box) till we plumped for a new LCD set. Just want to try to fix the Panny for use in Portugal and then find her a deserving new home. Obrigado (thank you)
GRC
18-06-2009, 11:18 AM
#15 (permalink)
| | Prominent Member
Thanks: Gave 186, Got 381 | Re: Panasonic TX-28PL10? Quote:
GRC | See if it has a setup or tuning menu that asks for either the PAL Standard or Country to be set before (re)tuning.
Chris muriel, Manchester
