Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 13-06-2003, 11:37 PM   #1 (permalink)
On a budget and need help spending my money
Hey, first post on these forums and Im already asking for help , oh well.
Im currently looking for a bargan price 32" Widescreen to replace my laughably inferior old 28" 4:3 model. The TV will be used to play games on ALOT (were talking Xbox,GC,PS2 and PC hooked up through SVHS). I have set myself the price point of £400 (I know, I know, but I said budget), but about £20/£30 extra would be ok if necesary.
Im not a complete newby at looking for quality stuff at cheap prices and have managed to track down a few models. What I need are opinons on what features I should try to get. Im shopping alot on ebay and you can get good deals on there if you look around.
For example I have found a Thomson 32WF401G 32 inch xtraflat tube. Widescreen. 100hz picture for £410 at my door.
What I need are some ideas about what to look for in features where to try shopping.
For example Iv heard that 100hz can be almost obsolete when concerned with games so is it worth the extra? And is it realy worth it for the widescreen if its going to distort the pictures of the games?
Cheers in advance for any advice and please ask if any more info on my situation is needed.
SadaraK is offline   Reply With Quote
Old 15-06-2003, 6:15 PM   #2 (permalink)
Can anyone help me?
Old 15-06-2003, 6:19 PM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
For quality a 32" at £400 is going to be lower end. A stonking 28" will be a better quality buy at that price. If you must go for 32" try S/H or ex display models (stay clear of Currys etc) or try LG they were lovely sets a year ago but getting a bit older now so you can get them cheap. Make sure the TV is NTSC compatible and has S-video connections, RGB would be better if you can.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 15-06-2003, 6:20 PM   #4 (permalink)
nathan_silly
Posts: n/a
"For example Iv heard that 100hz can be almost obsolete when concerned with games so is it worth the extra?"
This doesn't make any sense. Games are still 50 or 60hz (depending on PAL or NTSC) so having a 100hz (could) be better. But IMO I don't like 100hz sets.
"And is it realy worth it for the widescreen if its going to distort the pictures of the games?"
Some of the better sets have a decent squah mode (squashes more in the centre, compared to the outer regions. So people in the centre look fine, but people on the side could be slightly stretched. But since you look at the centre of the screen anway you don't notice it.
Old 16-06-2003, 1:21 AM   #5 (permalink)
Thanks for the tips. Can anyone recomend a good place (exept ebay) to shop for old LG, ex-display and S/H models?
budget, money, spending
