Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Please Help - How To Change NAT Settings!! Mr Cole Xbox Live 37 09-04-2009 9:59 AM
How Do I Change NAT Settings?? Mr Cole Xbox Live 19 14-06-2008 7:13 AM
how do i change proxy settings?? nathan_2580 iPhone Discussions 4 07-06-2008 12:54 AM
Sharp Sharp LC32P50E - Optimal Video Settings? dougsdir LCD Televisions 8 14-01-2006 11:13 AM
MCE Remote - can I change the settings? Wild Weasel Windows Media Center Edition MCE 4 13-01-2006 1:23 PM
Old 22-09-2008, 11:42 AM   #1 (permalink)
Thanks: Gave 1, Got 0
Sharp SX66NF8 - change PAL settings?
I have recently returned from Australia and brought home a Sharp SX66NF8 television. It is picking up the picture signal perfectly but the sound is distorted with noise. I can hear the dialogue but I can hear the crackling more! A friend suggested changing the PAL settings however I cannot find where to do this on the menu. Another suggestion was to change the country settings to Ireland however again I cannot find how to do this. I'm wondering is there a hidden menu via the remote which will allow me to do this via a specific sequence of buttons? Any help or advise would me much appreciated. I tried Sharp UK and they only help on UK televisions.
RonanM is offline   Reply With Quote
Old 22-09-2008, 6:26 PM   #2 (permalink)
NST
Thanks: Gave 9, Got 48
Re: Sharp SX66NF8 - change PAL settings?
This is a fairly modern TV, so the likelihood of an option to change the audio setting should be present in the engineer/ service menu. I can't confirm this for sure though.
Your best option may be to use a Freeview box with it, as this will bypass the TV's tuner circuitry.
NST is offline   Reply With Quote
Old 23-09-2008, 9:25 AM   #3 (permalink)
Hi NST,
Thanks for this. I have a digital tuner which I might try and run the signal through. I presume this should do the same as a freeview box? One other suggestion I've got is to change the chip set that controls the audio in the TV but it sounds like an expensive option so I'm keen to avoid this.
Cheers,
Old 23-09-2008, 10:18 AM   #4 (permalink)
NST
Hi, any external tuner box (Freeview/ Sky/ Cable) plugged in via the SCART or A/V will be fine. It's the cheapest option as converting your TV may be uneconomical, especially if it is not DIY fixable (via service menu). Even calling out an engineer to tinker with the settings would end up costing more than a basic Freeview box!
Yes in some TV's, especially older (or simpler) ones, the sound filter crystal would need to be changed from 5.5MHz to 6MHz, to work on the analogue PAL format in the UK (PAL-I). It's sometimes not as straight-forward as it looks, as the whole tuner module may have to be swapped (expensive).
RonanM (23-09-2008)
Old 23-09-2008, 3:58 PM   #5 (permalink)
Thanks again, I'll go for the digital tuner first and see how I go...
change, pal, settings, sharp, sx66nf8
