| Re: Laptop to CRT TV via yellow rca
Not sure what you mean by S-VGA, but I don't think this will work. If you had a VGA on your TV, this would be ideal. Otherwise, laptops usually have S-Video outputs, which will connect to almost any TV. If yours doesn't, you could try a VGA (+sound) to SCART adapter, though I'm not quite sure the best place to get one of these, nor how expensive they are. Anyway, hope this helps a bit.
__________________ AV: Hitachi P50TP01U (Swivel Stand!) - HTPC - Onkyo 705 - Tannoy SFX 7.1 - Wii HTPC: ASUS M3N78-PRO, LG GGW-H20L (Bluray & HDDVD), 2.6TB HDDs, 4GB DDR2 (1066), Phenom X4 9950, Happauge WinTV HVR-4000
