Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
JVC AV-32T5SK or Toshiba 28Z47B SpongeCake CRT Televisions 3 09-01-2008 10:15 AM
Final Destination 3 £4.00 nwgarratt DVD Bargains and Discount Codes 5 23-05-2007 8:16 PM
Toshiba 28Z47B or 28Z44 silps CRT Televisions 2 06-12-2005 9:46 PM
Sony KV28HX15 or Toshiba 28Z47B Opinions please.. vidkid CRT Televisions 1 07-01-2005 11:16 PM
Final Destination !!! RMCF Movies and The Cinema 11 02-11-2000 6:59 PM
Old 10-09-2008, 11:29 AM   #1 (permalink)
Thanks: Gave 1, Got 0
Tosheba 28Z47B CRT Destination problem
i wanted to know if i can change the destination of the Toshiba 28Z47B from UK to other destination and if i can how. thanks.
amptronic is offline   Reply With Quote
Old 11-09-2008, 10:05 AM   #2 (permalink)
Thanks: Gave 4, Got 36
Re: Tosheba 28Z47B CRT Destination problem
It very much depends on where you want to take the TV to.Many settings can be changed in the service menu to allow operation in different countries -but not all.It is not adviseable to make adjustments without knowing what the settings should be as you can cause all sorts of problems and make the TV unusable.
mechanic is offline   Reply With Quote
amptronic (16-09-2008)
Old 11-09-2008, 2:10 PM   #3 (permalink)
OK i am going to use it in Ghana ( ie Pal B/G) but i will be glad if u will let know what to change as i can enter the service and the d. modes. thanks.
i think is the same like the holland recepttion.
28z47b, crt, destination, problem, tosheba
