Hi terminus,
As Grumpy Old Troll suggests, you do have to see it really. It's one of those things an engineer can generally diagnose instantly, to describe isn't perhaps so easy but we'll have a go.
Might be worth looking for any of these (admittedly fairly basic) symptoms,
1. Does it seem to take longer for the picture to appear from a cold switch on than when it was newer.
2. When the picture appears is it "tinted" at all gradually becoming better over a minute or two.
In particular is the red slow to warm up, are faces greenish slowly becoming more natural. Due to the makeup of the signal all the three guns (red green and blue) in the CRT are not driven equally, red is most hard driven. This is a fairly good guide to failing emission.
3. Put something like CBeebies on, you want something with loads of heavily saturated colours. Turn the colour and contrast and brightness up high. Do any of the colours "flare" out to the right.
4. How is the focus. Is it noticeably worse at the screen edges. Does it "defocus" on high brightness scenes ?
If you turn up the brightness fully is the picture bright even if it is not clear ?
Can you brighten what would be dark areas of the picture or not ? This perhaps points to other trouble if you can't.
Let us know what it does and how you get on
