Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 09-05-2003, 12:48 AM   #1 (permalink)
Incorrect red colour registration on Toshiba 36ZT29B - help please.
It would seem that all my reds are shifted slightly (2/3millimeters) to the right of the main image. This especially shows up on the red dot DOG on Sky etc...
Is there a setting in the service or designer menu to alter the registration of the red colour ?
Regards,
Dom
dompotter is offline   Reply With Quote
Old 09-05-2003, 3:16 AM   #2 (permalink)
kwangomango's Avatar
Thanks: Gave 6, Got 19
Are you getting the same problem with DVDs?
My Sky Digital box suffers from the Chroma Bug with causes all reds to smear outside of their boundaries.
Other than that you may have a convergence problem. This is where the R G and B from the guns do not overlap correctly. A white dot is white cos the three colours converge correctly and give white. If say red wasn't converging correctly though, you would see red on an edge of the dot and not quite white on the opposite edge. This can be checked using a test pattern on a disc like Avia.
kwangomango is offline   Reply With Quote
Old 11-05-2003, 1:48 PM   #3 (permalink)
Thanks: Gave 0, Got 2
This "chroma bug" - I assume it isn't fixable from the digibox service menu? Does is appear on some makes of digibox only?
Alan D is offline   Reply With Quote
Old 12-05-2003, 1:23 AM   #4 (permalink)
http://www.hometheaterhifi.com/volum...ug-4-2001.html
Bit technical but look at the reds in the images at the foot of the page. That is what i get on my Amstrad DRX100. It is just a fault in the mpeg decoder on certain digital devices.
Old 12-05-2003, 5:58 AM   #5 (permalink)
If you see it through normal off air broadcasts or DVD it is more than likely a convergence error. There is a specification, depending on the area, of how much drift you can have before thie tube is deemed unacceptable. I think on a 36" it's 1.5mm in the corners, but don't quote me on that. This can be adjusted but not in the service menu. It is a manual crt adjustment so I would get an engineer out if it looks severe.
Knickerzohnonov is offline   Reply With Quote
36zt29b, colour, incorrect, red, registration, toshiba
