Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Wii Sensor problem - not picking up remote snollygoster7 Wii 7 19-02-2007 7:13 PM
Remote sensor rrp Remote Controls 1 03-12-2006 12:11 AM
Sony kf-42sx300u remote sensor problem johnno1970 Rear Projection Televisions 6 29-12-2005 2:43 PM
Arcam 79 - remote sensor MarkTy DVD Players 1 14-07-2005 5:05 PM
Old 02-04-2008, 2:07 PM   #1 (permalink)
Problem with remote sensor...
Having thought for a couple of months that the remote for our Goodmans TV/DVD combo (GTV 51RF DVD) simply wasn't working, I decided finally to go out and buy a universal remote. However, this didn't work either, and I can only conclude that there is a problem with the remote sensor?
If this is the case, how do I go about getting it fixed, and (roughly) how much would it cost? Not having a remote has never bothered me before, but I've just bought an Xbox 360 and without the AV button I can't use it, so I need a quick solution!
There is no AV button on the set either, and changing the channel below 0 doesn't get to AV either, so I really am stuck until this is sorted.
Any help would be greatly appreciated!
bexxx is offline   Reply With Quote
Old 02-04-2008, 2:17 PM   #2 (permalink)
NST
Thanks: Gave 9, Got 48
Re: Problem with remote sensor...
Could be the remote sensor is dirty. I know it sounds obvious, but try cleaning the front of the TV around the controls and power button. As for the 360, try an RGB SCART cable as this will normally auto switch the TV to the AV input, and will provide you with better image quality as well.
NST is offline   Reply With Quote
Old 02-04-2008, 2:26 PM   #3 (permalink)
Thanks: Gave 3, Got 31
you can "see" the led flashing on a remote control when you press a button if you view it with a digital camera ( & mobile phone I guess?) this was you could at least check that the remote is transmitting?
CGizzi is offline   Reply With Quote
Old 02-04-2008, 6:55 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
In what way?
Did you just try the codes listed for Goodmans?
Most "universal" type remotes have a "search" mode whereby the remote emits all the codes in it's memory one after the other while pointing it at the set...either automatically or by you holding down or pressing then releasing a button such as the standby button...check its user manual...once the set switches off you have found the correct or a near code.
That model of Goodmans is unusual in that it uses a chassis made by "Haier" so look in the universal remotes user manual for codes listed (if any) under that brand...or the search method.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
problem, remote, sensor
